**@CAPACITY**Idyllwild 4/29 camping-wheeling-(most likely bs too)
Discussion in 'Southern California' started by YotaGurlIAm, Mar 30, 2016.
  1. Apr 21, 2016 at 9:02 PM
    #921
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    @MuricaTaco Nick, a dual antenna setup is easy, but, like I thought, you need a "co-phased" cable. I also read-up on the signal pattern. Pretty easy when it comes down to it. But, you just need that special cable or else it won't work. I read-up on dual antenna setups a long time ago and remembered that there was something special about that setup. It would be neat to do one for sure!!! As far as the RF signal pattern, you actually INCREASE range front/back, but your left/right sides get hammered to shi-!!! So, which is it gonna be, "head or stomach", LOL!!! Finally, it is still advisable to get as long of an antenna as possible for dual setups!!! Just for your information!!!
    I wish you brought your antenna so that we could have checked out the final setup! I know, for a fact, with a 4ft whip, you can easily get 4-6mi even within city areas. I was talking to one guy that was about 5mi away, IN the city area (i.e. buildings, trees, etc) and he was coming in nice and clear!!! Alot of it has to do with the tuning of your antenna system and, of course, wattage output (handhelds typically have less wattage output and this is more likely to save battery power)! I have a COBRA handheld that outputs around 2watts. Mobiles will typically output close to the max of 4watts, which was the other thing I wanted to check out of your radio with my SWR/Watt meter... AND... I found my damn cables I was looking for, LOL!!! My dumba$$ packed them in a box... since I'm moving alot of stuff to storage, LOL!!! WTF, WHY pack when I'm unnnnpacking shi- all over again??? LOL!!!
    Anyways, can't wait to install the 4ft whip and whatever configuration you decide to go with?
    ODNAREM likes this.
  2. Apr 21, 2016 at 9:12 PM
    #922
    YotaGurlIAm
    YotaGurlIAm [OP] Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    Ohhhhh, gotcha. Maybe someone will get a meet together closer to where ur at.
    As for this one, there's already so many ppl coming I'm worried about the integrity of the trail runs. It's just annoying with all the stop and go of a zillion trucks on a narrow trail hahah. We'll see how it goes.:notsure:
  3. Apr 21, 2016 at 9:23 PM
    #923
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Yeah I definitely get that. Too many trucks can make a run a nightmare. Makes it annoying for the people at the back if there's a tough spot and for anyone trying to pass
  4. Apr 21, 2016 at 10:12 PM
    #924
    NotRed
    NotRed Well-Known Member
    taken from Firestik's page, optimal distance between co-phased (twin) antennas is 9', can run as narrow as 5'
    Would be a problem on any small truck. Not to say it's impossible but may be more trouble than it's worth.
    "SPECIAL CONSIDERATIONS
    Single antenna installations for 2-Way Radio requires 50-ohm coaxial cables such as RG-58A/U or RG-8X. Dual antenna installations require 75-ohm coaxial cable (co-phase harness) to perform properly. Note: From time to time we hear from people in the field that have made co-phase harnesses from 50-ohm coax and report better than average SWR. In tests performed at our facility we found that the lower SWR readings were a results of power losses that often exceeded 50% of the radio output when compared to RG-59A/U coax and higher SWR readings. Accordingly, do not use 50-ohm coax for co-phase antenna installations.
    Spacing of the antennas in a dual antenna installation will have an affect on the radiation pattern of the antennas. Technically, spacing between the antennas should be nine feet (2.7m) to have the most balanced pattern. If that distance cannot be achieved, that alone should not discourage you from using co-phased antennas as you will still receive most of the benefits of a dual antenna set-up. However, spacing less than five feet (1.5m) may require some special tuning skills in order to achieve satisfactory SWR readings."
    ODNAREM and WileECoyote[QUOTED] like this.
  5. Apr 21, 2016 at 11:23 PM
    #925
    WileECoyote
    SoCal
    Thank you for this! I was reading more about co-phase antenna systems. Pretty interesting read!!! I still wouldn't mind trying something either way though! :thumbsup:
  6. Apr 21, 2016 at 11:28 PM
    #926
    NotRed
    For sure, worst case is you can't get your VSWR down to an acceptable level and go back to a single antenna (after replacing the cable too).
    ODNAREM and WileECoyote like this.
  7. Apr 21, 2016 at 11:45 PM
    #927
    WileECoyote
    SoCal
    LOL, yeah, no kidding, huh! I'm expecting that same result!!! LOL!!! Again though, thank you for helping me look into this as well!!! :thumbsup::fistbump:
  8. Apr 21, 2016 at 11:51 PM
    #928
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Bust through dem obstacles :ballchain:
    I'm just sitting over here like :boink: reading all this radio talk hahaha, maybe I'll be able to get my head around it after I get some sleep finally this week :D
    Hope there's not too much stop & go, otherwise it'll be like Main Divide how I was worried about getting stuck on every stop hahahaha:rofl:. What trails are we planning for Saturday anyways? Oh and is your friend Cameron coming out, guy with the ranger:confused:
    WileECoyote[QUOTED] likes this.
  9. Apr 22, 2016 at 6:57 AM
    #929
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    Nah that kid doesn't talk to me anymore, got butt hurt or something. We're doing Thomas mountain and Black mountain
  10. Apr 22, 2016 at 7:35 AM
    #930
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Is everyone going to be on a CB or HAM radio? I'm picking up a handheld HAM radio today.
    eccracer104 likes this.
  11. Apr 22, 2016 at 7:55 AM
    #931
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    I'm ham
    eccracer104 and 06HAOLE like this.
  12. Apr 22, 2016 at 8:06 AM
    #932
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    :pccoffee::wave: Speaking of Ham radio I need to charge mine
    digitaLbraVo, ODNAREM and WileECoyote like this.
  13. Apr 22, 2016 at 8:13 AM
    #933
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    @YotaGurlIAm
    Replacing my bearing this weekend. Also getting some ditch lights for the truck and Sidneys quad. Going to retro a Cali-Raised
    White for Sids headlight
    Also it looks like if i go i will be a looner.
  14. Apr 22, 2016 at 9:15 AM
    #934
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Its a stock height 2wd 5 lug non pre-runner, not much fun off-road, lol
    Tons of fun on the street though, hope you guys have fun!
  15. Apr 22, 2016 at 9:27 AM
    #935
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I'll be on HAM as well :thumbsup:
    digitaLbraVo and 06HAOLE[QUOTED] like this.
  16. Apr 22, 2016 at 9:30 AM
    #936
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
  17. Apr 22, 2016 at 9:46 AM
    #937
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I prefer the yelling out the window method :notsure: but I have a CB and a ham :bananadance:
  18. Apr 22, 2016 at 10:44 AM
    #938
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    False I like running in the back. You can help people if there is a tough spot, and the front of the pack should realize it is tough and help as well. As far as people trying to pass fuck'em we are 20 trucks deep
    I eventually want a snorkel, but think it would look dumb on my truck at the moment :pout:
    Idk why you were worried... everyone else was in 2wd and you have an automatic.... I only went in four to get past things people struggled on and didnt want to waste my time, lol
    lol
  19. Apr 22, 2016 at 11:31 AM
    #939
    Speed Freek
    If no HAM is Turkey OK?
  20. Apr 22, 2016 at 11:53 AM
    #940
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Naw man you need cheese!
