Car and Driver Comparison: 2016 Tacoma v. 2016 Colorado
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colorado S14, Oct 4, 2015.
  1. Oct 5, 2015 at 7:55 AM
    #101
    JasonTsunami
    JasonTsunami Well-Known Member
    Katy tx
    16 Tacoma DC SB tss
    None
    Which Mazda truck was this working on?
  2. Oct 5, 2015 at 7:57 AM
    #102
    MikeD72
    MikeD72 Well-Known Member
    You have to remember this is in a truck that has to do a lot of ballsy things. Look at the Highlander or Rav4 if you want to compare to Mazda. Mazda doesn't make a truck or a body on frame to compare.
  3. Oct 5, 2015 at 8:01 AM
    #103
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    I slammed on the brakes during the test drive and I was impressed as well.
  4. Oct 5, 2015 at 8:04 AM
    #104
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    True. This is like saying the 4 banger in my Corolla gets 38-40 mpg and the 4 banger in the Tacoma only gets 24. There doing something wrong. No. There's just a huge difference in its use.
  5. Oct 5, 2015 at 8:08 AM
    #105
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    24 highway. 30 is the diesel. In town only you can expect a few mpg's below the low of 19. Both colorado and tacoma have similar mpg ratings for the has engines. Pretty much a toss up. I but into consumer reports and even though they rate the tacoma the lowest of all trucks it is the highest in reliability. They say it is to utilitarian or truck like. Well reliability and truck like is what I like. Try fitting a 1 up tire on the colorado, try off roading with the low approach angles, it's not going to happen. 0-60 is not that big a difference.
    Those complaining of low tech make we wonder why qi charging is low tech. As well as the ability to use your phone navigation and see it on your head unit. I know of no other vehicle with this capability.
    TacoBella likes this.
  6. Oct 5, 2015 at 8:10 AM
    #106
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    Totally agree which why I bought a Tacoma.
  7. Oct 5, 2015 at 8:12 AM
    #107
    big_jarv
    2020 TRD Pro
    That is a thing on the new Tacoma?
    That's awesome!
  8. Oct 5, 2015 at 8:24 AM
    #108
    the phew
    the phew Well-Known Member
    Upgrades in technology that make an engine more efficient from a thermodynamic perspective (chemical energy in the fuel to shaft power at the wheels) will provide roughly the same % benefits whether its propelling a sedan, truck, or toaster. The new Tacoma isn't significantly heavier or larger than the old one, so you'd think going from an ancient port-injected lump to an advanced DI engine with Atkinson lobes and 12.5% less displacement coupled to a more efficient transmission with taller gearing would result in some tangible fuel economy improvements.
    It's not like the Tacoma got massively more capable in Gen3; the suspension, differentials, wheels, etc are all basically the same as Gen 2. On paper, that engine/trans/aero should have lowered fuel consumption by ~20% based on other vehicles that have made similar improvements (like the Mazda sedans I mentioned).
    Then again, Ford's 2.7L DI turbo engine coupled with the weight loss from more aluminum should have yielded massively better fuel economy than competing engines, yet real-world fuel economy is still the same as Chevy's n/a 4.3L V6. Diesel seems to be the only way to get decent fuel economy in a midsize or larger pickup?
    Tharris242 likes this.
  9. Oct 5, 2015 at 8:27 AM
    #109
    Joe333x
    Joe333x Well-Known Member
    Just imagine how much better it would preform with discs though.
  10. Oct 5, 2015 at 8:30 AM
    #110
    MikeD72
    The V6 has improved in mpg, albeit slightly, but it has. Again, Toyota plays it safe. They are not going to spend all their time trying to improve mpg drastically and make the truck drive like a car (That's GM's job). Mike Sweers says over and over, their main concern is reliability and durability.
  11. Oct 5, 2015 at 8:30 AM
    #111
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    Your right to an extent. Trucks and cars are a different breed. But. For your betterment well use your numbers. 2nd gen 4x2 4.0 avg (according to real world #) about 20 mpg. So by your figures of 20% I should get 24. image.jpg
  12. Oct 5, 2015 at 8:39 AM
    #112
    the phew
    You (and everyone else with a Gen3) should start a Fuelly account for your truck. A couple snapshots of brief highway jaunts don't tell the story; thousands of fill-ups from hundreds of users on Fuelly do.
    Tunngavik and ZachMX like this.
  13. Oct 5, 2015 at 8:40 AM
    #113
    LaPorta
    LaPorta Well-Known Member
    Regarding the shifting, driving both the Canyon and Colorado netted me a gear-hunting session as well. Why is the Tacoma singled out for that?
  14. Oct 5, 2015 at 8:41 AM
    #114
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    I'm sure that is exactly what's going on. But considering only hundreds have been sold and most have only filled up a few times. It's gonna be a while. So these pics are all we have for now. But I fully expect to avg about 23 or 24 once I really start using it to commute.
  15. Oct 5, 2015 at 8:44 AM
    #115
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    How about we just care about how it performs? Lots of cars run disk brakes that are worse than or at best no better than drums but give the manufacturer an incentive to jack up prices for people like you.
    PS, Colorado has rear disk brakes. Doesn't seem to be a whole lot better.
    bdunna likes this.
  16. Oct 5, 2015 at 8:45 AM
    #116
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    I feel it's really pronounced in the new V6 especially with the ETC turned off. From the take off under normal exceleration it nearly goes right into a low rev 2nd then short shift 3rd into 4th at about 35mph. So when you give it a little gas it kinda waits to figure out if it needs to drop down or slow accel
  17. Oct 5, 2015 at 9:24 AM
    #117
    LaPorta
    The twins did the same to me. I'd hit the gas and then wait a second, only after which the engine decided to do something. The real solution to this is going back to direct connect throttle bodies. Having the car try and guess what you want instead of it just doing what your foot does is annoying.
  18. Oct 5, 2015 at 9:31 AM
    #118
    BeaverNation
    BeaverNation Well-Known Member
    or a manual transmission. There is zero lag when in gear
  19. Oct 5, 2015 at 9:43 AM
    #119
    .28
    .28 TacoRunnerCamry
    miguel
    Texas
    2016 TRD Offroad DC 4x4
    I think their benchmark in reliability speaks for itself..
  20. Oct 5, 2015 at 10:11 AM
    #120
    dlakerguy
    dlakerguy Well-Known Member
    The Colorado has a rear locker. A much better one too. It also has way more features you didn't list that the Tacoma doesn't have. 4G wireless, onstar, longer warranty, the rear step bumper (waiting for Tacoma to steal this like they stole the tailgate self lowering feature) and more I am sure.
