Car battery keeps dying !?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Esagrera, Oct 29, 2024.
  1. Oct 29, 2024 at 6:55 PM
    Esagrera
    Esagrera [OP] Member
    Lalo
    2022 Toyota Tacoma
    Hey guys ,
    My cars battery keeps dying as soon as I turn the car off ,
    My truck is a 2022 Toyota Tacoma so I doubt the alternator already went bad on it ,
    Do you guys have any suggestions ? any fuses I need to check ?
    what can I do to figure the problem out ?
    thomasburk likes this.
  2. Oct 29, 2024 at 7:00 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you had the battery tested? Sounds like a bad battery.
  3. Oct 29, 2024 at 7:01 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    1. Unplug any aftermarket electronic doodads. Including phone chargers etc
    2. Have the battery load tested by someone that knows what they’re doing
    3. Check for parasitic draw
    4. If driving short distances, try driving it for a longer amount of time
  4. Oct 29, 2024 at 7:05 PM
    MGMDesertTaco
    Replace the battery.
  5. Oct 29, 2024 at 7:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    5. Check the voltage when the engine is running. It should be about 14v (alternator output) when running and about 12v (battery output) when not running.
    Barsoom and Chew[QUOTED] like this.
  6. Oct 29, 2024 at 7:13 PM
    Esagrera
    Lalo
    2022 Toyota Tacoma
    Guys I’ve already replaced the battery twice it’s not the battery
  7. Oct 29, 2024 at 7:15 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    But you say if you turn the truck off and immediately try to restart it nothing happens?
    How do you get it started then?
  8. Oct 29, 2024 at 7:17 PM
    Esagrera
    Lalo
    2022 Toyota Tacoma
    Correct and I’m starting it with a battery jumper
  9. Oct 29, 2024 at 7:20 PM
    gudujarlson
    Minnesota
    If you have ruled out the battery, then the problem is likely the alternator or a parasitic draw. You can easily test each with a multimeter. Avoid throwing money at the problem by replacing parts that might not be broken.
    Barsoom likes this.
  10. Oct 29, 2024 at 7:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No battery dies that quickly (it would take an insane amout of current to kill a good battery in minutes) if it's good, have you verified that it's charging? As stated above it should be near 14v (13.2v minimum) with the truck running and about 12.6v (12v minimum) with the truck off.
    STEELeR43 and MGMDesertTaco like this.
  11. Oct 29, 2024 at 7:22 PM
    Esagrera
    Lalo
    2022 Toyota Tacoma
    The alternator bad on a 2 year old truck ?
    Also if it was a parasitic draw wouldn’t it take time for my truck not to start after ?
    Because it immediately doesn’t start after driving it.
    I just drove it for 6-8 miles on the highway to charge the battery and nothing. soon as I turned it off the battery was dead and wouldn’t start.
  12. Oct 29, 2024 at 7:23 PM
    gudujarlson
    Minnesota
    I can't say, but testing for both is simple and easy. There isn't a better way forward. I would check the alternator first, because it is the easiest.
    Either the battery is not holding a charge, the alternator is not charging the battery, or there is an excessive draw on the battery. I suppose also there could be a problem with the ECU, start button, or something... some electrical gremlin, but I suggest ruling out the easy ones first.
    CAVEAT: I would actually expect the truck to give you a message if the alternator was not working, but since it's never happened to me, idk.
  13. Oct 29, 2024 at 7:28 PM
    MGMDesertTaco
    Battery connections tight?
    musicisevil likes this.
  14. Oct 29, 2024 at 7:28 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Do you have any aftermarket electrical work? Did you take the plastics off the battery posts?
    Cudgel and Dm93 like this.
  15. Oct 29, 2024 at 7:32 PM
    Esagrera
    Lalo
    2022 Toyota Tacoma
    I had to get one of my speakers replaced because it blew, but I was already having this issue prior.
  16. Oct 29, 2024 at 7:36 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    you don’t know until you get them both checked. There is no rule that says “just because it’s new, means its guaranteed good.”
  17. Oct 29, 2024 at 7:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Go get the battery and alternator tested, most auto parts stores will do it for free.
    If your gona refuse to test/check anything I'm not sure how we're supposed to help.
  18. Oct 29, 2024 at 8:17 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Are you running a AGM battery?
  19. Oct 29, 2024 at 8:20 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    2 year old truck. If the battery has been replaced several times and you don’t have aftermarket electronics, go to the dealer and have them diagnose under warranty.
    agreed, OP seems a bit volatile.
  20. Oct 29, 2024 at 8:23 PM
    Bishop84
    Bishop84 Well-Known Member
    It sounds like a battery issue to me :anonymous:
    shakerhood, musicisevil and Chew like this.
