Car battery keeps dying !?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Esagrera, Oct 29, 2024.
  1. Oct 30, 2024 at 8:09 AM
    #41
    Esagrera
    Esagrera [OP] Member
    Lalo
    2022 Toyota Tacoma
    I figured it out guys ,
    It was a bad battery terminal
    shakerhood, Dm93 and musicisevil like this.
  2. Oct 30, 2024 at 8:17 AM
    #42
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    Costly $$$ diagnosis unfortunately.
  3. Oct 30, 2024 at 8:21 AM
    #43
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this is 100% the jumping off point for this problem and ones that are similar.
    if you want me to punt, i vote starter solenoid has a short.
    thomasburk likes this.
  4. Oct 30, 2024 at 8:28 AM
    #44
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    That is why always you start with the basics. Battery terminal connections is the basics, not checking all kind crap first. What did you do, replace battery terminal with cheap style terminals?
    shakerhood likes this.
  5. Oct 30, 2024 at 12:56 PM
    #45
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Look for water damage. Now I think starter issues with solenoid.
  6. Oct 30, 2024 at 12:58 PM
    #46
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Just needed tightening?
  7. Oct 30, 2024 at 12:59 PM
    #47
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
  8. Oct 30, 2024 at 1:40 PM
    #48
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Wow.
    As usual most start issues are the battery or cable or connections to battery.
    So simple but most people refuse to try it first.
    Don't know why so many jump to alternator or starter or other things first.
    Also you don't need to buy vehicle from a dealership for warranty to be in effect.
  9. Oct 30, 2024 at 1:47 PM
    #49
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Because it takes 10 seconds to check the alternator. Checking the battery requires a load test which is not nearly as easy.
    I personally have not had a problem with a battery connection since the 1980's. I still have a battery post cleaner in my toolbox though.
  10. Oct 30, 2024 at 1:53 PM
    #50
    canuck guy
    Alberta
    23TRDOR
    Like I said in my post
    Most start issues are the battery or connections so check that first not alternator.
    Maybe you haven't had a battery connection issue in 40+ years but you're 1 in a million.
  11. Oct 30, 2024 at 1:57 PM
    #51
    gudujarlson
    Minnesota
    Checking the battery connection and checking the alternator can be done at the same time using a multimeter. Checking the battery is a whole different ball of wax.
    I never heard of anyone having a bad battery connection until this thread. When I've encountered it, it has been because of really bad corrosion on the posts or terminals. I think we might have a different definition of "battery connection".
  12. Oct 30, 2024 at 2:06 PM
    #52
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    An early Festivus miracle!
    shakerhood and musicisevil like this.
  13. Oct 30, 2024 at 2:07 PM
    #53
    gudujarlson
    Minnesota
    What do you mean by "bad battery terminal"?
  14. Oct 30, 2024 at 2:15 PM
    #54
    canuck guy
    Alberta
    23TRDOR
    I never heard of anyone having a bad battery connection until this thread. When I've encountered it, it has been because of really bad corrosion on the posts or terminals. I think we might have a different definition of "battery connection".[/QUOTE]
    Good grief. Yes I (and most) consider the point at the battery post with clamps to be the main connection. It can and is often compromised by corrosion and/or deposits or loose. Semantics.
  15. Oct 30, 2024 at 2:28 PM
    #55
    gudujarlson
    Minnesota
    Good grief to you too, Sir! We're obviously not communicating very well. Peace out
    musicisevil likes this.
  16. Oct 30, 2024 at 2:31 PM
    #56
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Good question
  17. Oct 30, 2024 at 2:39 PM
    #57
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    :rasta:
    MGMDesertTaco and thomasburk like this.
  18. Oct 30, 2024 at 3:47 PM
    #58
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I had a cracked terminal connection once on another truck. Wiggled it and started every time. Glad you found it.
  19. Oct 30, 2024 at 4:02 PM
    #59
    canuck guy
    Alberta
    23TRDOR
    ☮️:thumbsup:
