Car battery power inverters
Discussion in 'Outdoors' started by wawawewa, Jun 17, 2022.
  1. Jun 17, 2022 at 5:38 PM
    wawawewa
    wawawewa [OP] Member
  2. Jun 17, 2022 at 6:05 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Why do you need an inverter?
  3. Jun 17, 2022 at 6:11 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Depends on what I’m powering. Generally never need one here, everything I care about is DC.
    And lots of things that used to require ac can be done more efficiently on dc. Laptops for example
  4. Jun 17, 2022 at 6:40 PM
    01 dhrracer
    Still Shopping
    This is why I asked. It seems so many people have been sold on and have bought into the idea that inverters are a must.
  5. Jun 17, 2022 at 8:33 PM
    wawawewa
    just general stuff for when I out in the woods camping like a coffee maker haha
    jackn7 likes this.
  6. Jun 17, 2022 at 8:56 PM
    tcjacado
    tcjacado Well-Known Member
    They make coffee makers, blenders, microwaves and just about every other appliance in 12v.
    I have, can't remember the name of it,I use it to power the laptop, and sometimes a submersible pump where I don't have power to drain water.
  7. Jun 17, 2022 at 9:45 PM
    wawawewa
    yeah i figured.
  8. Jun 18, 2022 at 9:56 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    The factory one with two outlets added to the side of the center console. I used them primarily to charge camera batteries before the 12V chargers were common. I used to use them to power a netbook that I used for maps and I've also used them to run and charge my laptop (I think most gaming laptops still charge at more than 12V- my current MSI is 19.5V and under load will trip the factory inverter even in 400w mode; I did the 400w all the time mod on it). When I first got my fridge I just had a marine battery lashed in the back without a charger so I'd run the fridge on the bed outlet then let it automatically switch to the battery when I shut the truck off so that it helped save the battery- obviously the solution was to add a 12v outlet in the rear along with a way to recharge the house battery while driving.
  9. Jun 18, 2022 at 5:06 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Xantrex ProWatt 1000 Pure Sine Wave inverter. Just make sure you have a breaker between the battery and your inverter with an interrupt capacity at or better than the inverter. I have a blue sea 185 series for my inverter. If you are powering your laptop, ipad, gps, or other sensitive devices a true sine wave inverter is the way to go.
    Edit: I recommend only buying an inverter with an integrated GFCI circuit; they're more expensive but if you have the proper breaker on the supply side and the output side is a GFCI protected circuit you'll be golden and your electronics will be safe. A new iPhone is ~900 bucks so consider the cost of what you are powering before you skimp on the device generating the AC to charge it.
  10. Jun 18, 2022 at 5:15 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Question is How many power inverter will you be buying? How often will it be use? Any expensive computers?
    I vote buy the Sine wave. Offer 100% protection, vs 90% on the modified.
    I use my Sine wave every day, I lived off the grid, I use a deep cycle battery to my inverter. To recharge and power my iPad and cell phones.
    Most times this is a one time purchase, but I use mines a lot and this is my second one.
  11. Oct 26, 2022 at 8:40 AM
    mhemberg
    mhemberg Well-Known Member
    2021 Tacoma TRD OR
    I use a Kreiger and it works great. I never come anywhere close to its capacity. You can find them on ebay open box for 50 bucks. They were recommended by Will Prowse who is a solar power cult leader
    I use it more for tailgating for my kids hockey games than for camping but it works great for keeping the TV running.
    https://www.amazon.com/dp/B00T564EIY?_encoding=UTF8&language=en_US
  12. Oct 26, 2022 at 9:59 AM
    Lava-road
    2019 trd-off road
    Great you like this inverter. It didn’t mention it was a sine wave inverter, a a little bit concern here.
    I only use mines mainly for recharging and keep charging on my IPad ,cell phones and a portable fan for those hot days.
    I found the USB ports comes in handy. It is always in the on position.
    To run my plugs it has a separate on and off switch with a small green light to let me know it is ON. and when the battery runs low, it gives a annoying beeping “sound”.
    To run two USB ports I got a dual USB extension.
