Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Mar 24, 2014 at 9:58 PM
    #2921
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    From everything i've read the front diff and transfer case breathers are higher up (in the engine bay if i remember correctly) than the rear diff breather.
  2. Mar 25, 2014 at 12:16 AM
    #2922
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    They are right on top on the tcase and into the shifter
  3. Mar 25, 2014 at 4:41 AM
    #2923
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The front diff and ADD both have breathers that come up next to the main fuse panel behind the battery. The transfer case and transmission "Y" into one connection and their breather sits on top of the transmission. If you feel down between the engine bay and the firewall you should be able to find it. Of course the rear diff breather is on the pumpkin.
    I relocated all of them to a single home made open breather located up high on the firewall.
    Pictures here and here.
  4. Mar 25, 2014 at 7:06 AM
    #2924
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    The tcase and tranny breather is on the passenger side of the engine bay? I extended my rear diff breather some time ago and when I saw the cluster of breathers by the battery I thought I was good. Looks like I got one more to go.
  5. Mar 25, 2014 at 7:16 AM
    #2925
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's right on top of the transmission, basically in the center of the truck.
  6. Mar 25, 2014 at 7:19 AM
    #2926
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    I'll take another look. I searched for it before, but couldn't find it. It looks the same as the rear diff breather right?
  7. Mar 25, 2014 at 7:23 AM
    #2927
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's the same style breather as the rear diff, but it's on a piece of tubing. There are two hard line fittings, one on the transfer case and one on the transmission. They lead into a y and from that y there is a piece of tubing with the breather on the end. As far as I could tell it was just flopped on top of the transmission. Just feel down between the engine and the firewall over the transmission and you'll find it.
  8. Mar 25, 2014 at 7:26 AM
    #2928
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    I gotcha. I think I was searching too far back.
  9. Mar 25, 2014 at 8:21 AM
    #2929
    BamaToy1997
    Bill
    Navarre, FL
    On my current trailer build I am looking at the Dexter brand axle. I am thinking the 4,400 lb axle which comes with the 6 on 5.5 hubs, 3" diameter tube, and electric brakes. Total weight of trailer and cargo will be expected at no more than 3500lbs. What do you think?
  10. Mar 25, 2014 at 8:40 AM
    #2930
    Kanoodle
    Kanoodle Well-Known Member
    SLC, UT
    14 MGM. DC TRD-OR
    Wet Okole seat covers with heating elements Best Top soft topper Spidertax 1.25" wheel spacers Relentless Fab Hood hinge brackets with 18 watt LED Ditch Lights Prinsu Designs Cab Rack Tepui Ruggedized Autana RTT Expedition Orange Cooper SST MAXX E Rated tires Anytime Fogs mod
    Ok, thanks guy's for the input.
  11. Mar 25, 2014 at 11:20 AM
    #2931
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    ADD & front diff tied together, tube ends at the fuse box. The other tube that you will find right next to it, ending at the same location, is the trans & xfer case, which are also tied together.
    Crossing deep water? Get your intake up. Search the forum for my "Different Approach to a Snorkel" writeup (I'd link it, but I'm on my phone). $30 for a hidden snorkel that stays bone dry and looks stock.
  12. Mar 25, 2014 at 11:46 AM
    #2932
    SMKYTXN
    Nathan
    Houston
    DCFB
    That's not correct. The front diff and add have separate lines that run in parallel up to the fuse box. The transfer case and transmission are on top of the transmission
  13. Mar 25, 2014 at 11:56 AM
    #2933
    la0d0g
    running for the hills
    For crawling not hauling
    Unless you bury the hood or get water to come over it and it dumps in your cowl. Then you're potentially fucked. But then again, if your intake was in the stock position you would be too.
  14. Mar 25, 2014 at 12:01 PM
    #2934
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    so should these also be moved?
  15. Mar 25, 2014 at 12:08 PM
    #2935
    Mach375
    You have absolutely no clue what you're talking about. Go visit the thread -- the issue has been beaten to death :deadhorse:
  16. Mar 25, 2014 at 12:09 PM
    #2936
    Mach375
    Yeah, I realized that just after posting. My bad. (Wish there was an edit feature on the mobile versikn).
  17. Mar 25, 2014 at 12:41 PM
    #2937
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
  18. Mar 25, 2014 at 12:43 PM
    #2938
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Use tapatalk and there is....
  19. Mar 25, 2014 at 12:47 PM
    #2939
    SMKYTXN
    Nathan
    Houston
    DCFB
    Maybe, maybe not. I did just for my own piece if mind.
  20. Mar 25, 2014 at 1:16 PM
    #2940
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
