Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. May 2, 2014 at 9:44 PM
    #3461
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    https://www.arkportablepower.com/
    Group31m 100AH battery in mine :)
    Az
  2. May 2, 2014 at 10:44 PM
    #3462
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Pretty much the same thing as MRGRIMS pressurized water can. Minus the solar heater. I just did this to my scepter style water can. Just heated up with your OBA of your choice and BAM... shower
  3. May 2, 2014 at 10:48 PM
    #3463
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
  4. May 2, 2014 at 11:08 PM
    #3464
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    That and they're rated for 30 max per circuit. Run it through a decent circuit breaker right off the battery. If you're determined to use fuses, make sure you have a couple of extras in case they blow. This is why I went to a breaker, mine has blown fuses before.
    Just remember. 2 3" pipes is goign to be about half the capacity of a single 6 inch.
    Use a black can or spray it black and now it's a solar water heater too.
  5. May 2, 2014 at 11:19 PM
    #3465
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude, I love your relays and fuse setup...
    Now...go loom all those wires
  6. May 2, 2014 at 11:38 PM
    #3466
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'll be heading out on a trip again in a few weeks(moab). I'm going to try and pack light. Last couple trips ivd ended up with a big heavy load in the box and riding on my non-existent bumpstops. I just packed up my recovery gear so I'll have more space in the cab. Gonna bring my blanket and a pillow, some extra parts and fuel. Also probably just one cooler.
  7. May 3, 2014 at 12:26 AM
    #3467
    2008taco
    chris
    san diego
    Yeah I have a few more things to take care of with the wiring before I loom it. I'll get to it eventually.
  8. May 3, 2014 at 4:14 AM
    #3468
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Very clean setup. Mine looks like a rats nest
  9. May 3, 2014 at 6:39 PM
    #3469
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    I don't know where you have the compressor mounted, mine is in the bed. ARB told me to run 4 gauge wire with a 100 AMP inline fuse as close to the battery as possible. Leave in the 2 40 AMP fuses. I ran the ground to the frame. I did run the power through a 600 AMP Blue Sea switch (also ran my winch through the same switch). Only turn on the switch when I need to run the winch or compressor. Everything works great.
  10. May 3, 2014 at 7:20 PM
    #3470
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    When are you going?
  11. May 3, 2014 at 8:53 PM
    #3471
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    It works best for heating water quickly as aluminum is an excellent conductor of heat. We primarily use it as designed to rinse kids and gear off after the beach.
    In hot (+95°) sunny weather the road shower can get too hot to shower with and one must wait for it to cool or mix cold water in.
    In general I'm not a big fan of vehicle mounted showers.
    What I do mostly now is unscrew the sprayer from the road shower and bulk transfer the warm/hot water into a Nemo Helio pressure shower and move that wherever I want to.
    Hope this helps.
  12. May 4, 2014 at 4:45 AM
    #3472
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
  13. May 4, 2014 at 9:27 AM
    #3473
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  14. May 4, 2014 at 9:31 AM
    #3474
    el taco loco
    el taco loco Well-Known Member
    USA
    '13 DCSB Sport 4X4 in 1E7
  15. May 4, 2014 at 9:57 AM
    #3475
    ReaperTaco98
    ReaperTaco98 Reaper's Taco
    Ty
    Reno, NV
    Tacoma
  16. May 4, 2014 at 10:28 AM
    #3476
    Spoonman
    Jamie
    Alberta
    End of the month
  17. May 4, 2014 at 5:15 PM
    #3477
    2008taco
    chris
    san diego
  18. May 4, 2014 at 5:26 PM
    #3478
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    x2
  19. May 4, 2014 at 7:34 PM
    #3479
    Spoonman
    Jamie
    Alberta
    What the fuck happened to her hair
  20. May 4, 2014 at 7:44 PM
    #3480
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
