Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Jun 9, 2014 at 10:24 PM
    #3741
    trump
    trump Member
    Mark
    San Diego
    03 2.7L Tacoma 4x4
    Bunch-o-mods
    Gotcha, I agree with you on that.
  2. Jun 10, 2014 at 8:13 AM
    #3742
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Yep, terrible spot. That was about 5 years, and 4 cb setups ago. It's now centered on the truck, sitting up nice and high.
  3. Jun 10, 2014 at 10:27 AM
    #3743
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    i have mine mounted on the bed rail towards the tailgate using a wired ground... but im new to this tuning thing and i think i might have a bad ground situation on the antenna.
    that being said i have no idea if my swr meter is accurate... its got a little cal knob i can move around to make the needle go where i want. :confused:
  4. Jun 10, 2014 at 10:30 AM
    #3744
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Did the SWR meter come with instructions? If not, I bet it works like most others...
    http://www.cbradiomagazine.com/Articles/How to use a SWR meter.htm
  5. Jun 10, 2014 at 11:06 AM
    #3745
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    I don't know if anybody has mentioned, but your extra antenna coax cable should not be bunlded together (if you have extra). I wrapped mine around my rack to take up the extra length.
    I run a ham radio and can easily reach repeaters 100 miles away.
  6. Jun 10, 2014 at 11:26 AM
    #3746
    RustyBucket
    RustyBucket Well-Known Member
    The bed rail on a Tacoma is defintiely not an ideal spot for an antenna. Because of the Poly internal bed, you have hardly any ground plane. Ideally, you should have a flat sheet of metal connected to antenna ground at the antenna base.
    See quote below...
    Also, Bumper mounting will not only have an effect on range but also what direction your range is better in. If you have it on the rear like some jeeps do, you'll probably notice much better reception behind you than in front of you. The radio signal will be affected not only by the truck's body blocking the signal but also by signals being reflected off the truck's body.
  7. Jun 10, 2014 at 11:58 AM
    #3747
    TRD Auddie
    TRD Auddie NOT A FLAKE
    Austin
    Conyers, Ga
    03 TRD EC
    Not entirely true. You can bundle it together, but it has to be very tight. Loop it together where, when flat, the bundle is about 4-6" in length, then ziptie it very tightly together. Just not too close to the ends as to pinch and break the coax.
    I.E. In my previous truck (F150 ext cab) I had a Cobra 29LTD Classic and Francis 4' hot rod antenna using a 12' coax routed hidden through the cab w/ the antenna mounted behind the cab, on the bed. Excess coax was bundled tightly hidden in the dash. I could easily talk 4+ miles in downtown Atlanta.
  8. Jun 10, 2014 at 12:35 PM
    #3748
    nat
    2007 DC SB Tacoma
    If you get your ham radio license you will learn you should not bundle extra antenna cable. If you have to, don't bundle it in the shape of a circle or it will act like an inductor. You have to form it into the infinity sign/figure 8 shape.
    Like I originally said, your best bet is to not bundle extra wire.
  9. Jun 10, 2014 at 12:40 PM
    #3749
    nat
    2007 DC SB Tacoma
    You come over from Mud?
  10. Jun 10, 2014 at 5:11 PM
    #3750
    el taco loco
    el taco loco Well-Known Member
    USA
    '13 DCSB Sport 4X4 in 1E7
    This is hilarious. You HAVE to do A or else, certain doom! No, you HAVE to do B, or else, certain doom!
    WTF? Your best bet is to bundle, followed by your best bet being not to bundle. Good grief!
    Has anybody gleaned a single useful nugget from any of this? :)
  11. Jun 10, 2014 at 5:12 PM
    #3751
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    I learned that my antenna mount location us terrible, but it already knew that
  12. Jun 10, 2014 at 5:19 PM
    #3752
    el taco loco
    USA
    Well then, there you go! I hereby retract my smart-assed comments to the contrary. ;)
  13. Jun 10, 2014 at 7:07 PM
    #3753
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Mounted my shovel via quick fist mounts
    e2ab57f9d334a856bdf31f8bebf4ee7e_zps1fed_02bd7db8a238e88c9c3bafa18d60d15e29284da2.jpg
    e668718faee0d3d73f98a472e5724fd4_zps17eb_b250b38255989cc29689750e9046084b2d1ff19d.jpg
    cd05f26f81b2ba6da706b1b56d29ae6a_zps8178_570221c194d01bf46d369d456c3704848d4d0c5b.jpg
  14. Jun 10, 2014 at 7:12 PM
    #3754
    TRD Auddie
    Austin
    Conyers, Ga
    03 TRD EC
    Noted! :thumbsup:
  15. Jun 10, 2014 at 8:19 PM
    #3755
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    It could just be the angle but wont the shovel be hitting the topper if it rotates? If I'm right i would put something there so it wont wear a hole into your top.
  16. Jun 10, 2014 at 8:23 PM
    #3756
    2008taco
    chris
    san diego
    You think yours is bad? Apparently I'm lucky mine reaches further than the end of my driveway...
  17. Jun 10, 2014 at 9:30 PM
    #3757
    Maxx
    Maxx Well-Known Member
    You may just impale someone with that setup.
  18. Jun 10, 2014 at 10:41 PM
    #3758
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
  19. Jun 10, 2014 at 10:48 PM
    #3759
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    ^I think they are ugly. If I were to get a cap it would be the snugtop outback.
  20. Jun 10, 2014 at 11:00 PM
    #3760
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
