Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Apr 2, 2015 at 11:41 AM
    #4281
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i'll typically run ~18psi loaded up...usually not too much rock crawling if i'm loaded up so i'm not worried about going too slow...but helps when you come across sand or mud or the occasional ledge or obstacle...
    i'll be going through the maze next month and i'll have both rigs down to 18psi for that weekend..
    315/75/16 STT on the Tacoma
    285/75/16 Trail Grappler on the FJC
  2. Apr 2, 2015 at 11:51 AM
    #4282
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I'll say. Even some fairly large diesel/gas generators (larger than the set up in your picture atleast) can't even keep up with the loads. That is like a portable generator for commercial use, not the huge industrial ones. Im sure those batteries are pricey though. Seen some of those boat batteries in blue seas catalogues and man oh man they are pricey lol.
  3. Apr 10, 2015 at 1:18 PM
    #4283
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    I'm running 265/75/16 in load range C and I usually start out around 25 psi and adjust as needed from there. It's easier to let more air out than to pump them back up. I wouldn't be afraid to go down to 15 psi but you start to give up some ground clearance too.
  4. Apr 10, 2015 at 2:55 PM
    #4284
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I have mine at 35psi on the asphalt. 265/70r17 load range C (winter tires). I leave them at 35 for gravel roads and easy access to things some people count as "offroad", but go down to 20 for trails.
  5. Apr 10, 2015 at 3:38 PM
    #4285
    skygear
    skygear                    
    My 35x12.50r20 40psi on road. Off, I was running 0psi the other day
  6. Apr 10, 2015 at 7:22 PM
    #4286
    skygear
    skygear                    
    We were on a really bumpy beach/ trails. Speeds were 2-5 mph ) was interesting. Played with various PSI. With the 20"s, there was not a hell of a lot of rubber to work with.
  7. Apr 10, 2015 at 11:30 PM
    #4287
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    30 on 18 off
  8. Apr 21, 2015 at 8:01 PM
    #4288
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Does anybody use a Weather Guard Pack Rat for storage? Found an old one at a thrift store that I'm thinking about using.
  9. Apr 21, 2015 at 8:05 PM
    #4289
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I have a Jobox Storall built into my bed. It's a great solution for storage.
  10. Apr 21, 2015 at 8:09 PM
    #4290
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Used to have one in a company truck, they work great for keeping parts and tools organized. I've looked at see if I could use one a my work truck I have now.
  11. Apr 21, 2015 at 8:10 PM
    #4291
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Sub'd...
  12. Apr 21, 2015 at 8:13 PM
    #4292
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Agreed. Unless you are really hauling the mail and nailing a lot of boulders, lowering PSI will dramatically improve the ride. In boulder city I run 30 PSI (at speed, not crawling) but sometimes you can still break aluminum rims. I prefer steelies for this reason, and it's why I carry two spares on the taco. I've needed both more than once.
    (the good part is 0:43 seconds in)
    https://youtu.be/2SgAzs9-hLk
  13. Apr 21, 2015 at 8:20 PM
    #4293
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    wow. I typically run quite a bit lower than most of you it sounds like. I run 28psi on the street in both my Tacoma and my Cruiser. On moderate offroad trails, I'll drop to 15psi and in the more technical terrain I drop to 10-12psi.
  14. Apr 21, 2015 at 9:09 PM
    #4294
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Are you running an internal bead lock down near 10 psi?
  15. Apr 21, 2015 at 9:14 PM
    #4295
    Box Rocket
    Adam
    Syracuse, Utah
    Nope. Never have run beadlocks and never had a problem with beads coming off. A narrow rim will hold a bead better than a wide rim.
  16. Apr 21, 2015 at 9:38 PM
    #4296
    Box Rocket
    Adam
    Syracuse, Utah
    Nope both trucks have Load range C's
  17. Apr 22, 2015 at 6:46 AM
    #4297
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Interesting I didn't even know load c were available in the larger tires like many of us run. My 265 75 16 dura trace were but the coopers, km2 and generals that I have are all d or e
  18. Apr 22, 2015 at 7:09 AM
    #4298
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    He's running 15" wheels on his taco and lc though. For 15's there are some load C options
  19. Apr 22, 2015 at 7:37 AM
    #4299
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    MTR offers a C option for 315's and 35's.
  20. Apr 22, 2015 at 9:50 AM
    #4300
    Box Rocket
    Adam
    Syracuse, Utah
    Correction the 315s on my Cruiser are load range D. The KM2s on the Taco are C's
