Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Dec 31, 2015 at 1:15 PM
    #5501
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hey guys need some help and figured you all may be the best to ask. Solar panels. Trying to run lights in a shipping container that is completely off the grid. Going to be running 2-4 16.5ft led strips off of a battery. Need a solar panel that will trickle charge the battery.
    Was thinking of using a Coleman solar panel. Any things to consider when purchasing? Looking for something that will last but not be crazy expensive.
    Thanks for any help.
  2. Dec 31, 2015 at 2:38 PM
    #5502
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    All perfect points that I had not considered.
    More details is that there are two containers, each with 2, 5 metre strip lights drawing a total of 60wats, 5 amps each (total 10amps, 120watts if remember correctly from previous lighting projects. The containers are going to be used for storage of tractors, atvs, so run time would be an hour tops of one container at a time most likely a couple times a month. This is in Canada, and although they will not be used frequently throughout the winter months it should still be able to work.
    The lights will be DC (12v).
    Max draw will be 120watts
    Run time will be no longer than an hour a couple times a month.
    If you need any more detail let me know. Very new to all this and I'm not sure what too look for when buying a panel.
    Also panel doesn't have to be portable as it will be fixed to the container. We will be fixing it up higher to ensure maximum sun exposure.
  3. Dec 31, 2015 at 2:45 PM
    #5503
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks for the link, I'll take a look. I'm going to try and grab what ever panel through Amazon.ca or princes auto because of the exchange rate and shipping. May try and find a comparable.
    Also should have mentioned is the battery wil most likely be a Marin grade battery which will help with holding a charge and what not.
  4. Dec 31, 2015 at 3:02 PM
    #5504
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah you are right. The lights are 4.8watts per metre. 5 metres per strip is 24 watts. Have 4 rolls, that gives me 120 watts ( messed up my math earlier)
    That's 120/12v=10amps (messed that up last time too)
    Think I have it right now. Too many numbers for the holiday
  5. Dec 31, 2015 at 3:10 PM
    #5505
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  6. Dec 31, 2015 at 3:23 PM
    #5506
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Although that's a simple solution, the containers are pretty deep. Trying to make it so anyone can go to the property to use the equipment and not have to worry about lighting. Also if your by yourself and have to work on something it makes it a little nicer.
  7. Dec 31, 2015 at 4:26 PM
    #5507
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Absolutely I do agree, and the one time you forget it or what not it's a bit of an inconvenience . I'm trying to find one that's like a trickle charger for a car. Because we are not using it every day and it's so little draw it should suffice. Just want to cross reference this idea with everyone.
  8. Dec 31, 2015 at 4:38 PM
    #5508
    Leppz
    Leppz Well-Known Member
    Vancouver, BC
    2014 DCLB Sport Premium
    I have the Makita version of that light. The thing is seriously badass. It will light up a whole room and is great for camping.
    Considering the price of a solar setup these days I'd skip anything thats labeled as a "trickle charger" and just get the real deal.
    I have this 30W panel off Amazon.ca that I use with my truck, a cheap solar regulator, and a 105AH deep cycle marine battery. Keeps everything topped up quite nicely. I use it for LED lighting while camping, 12V Fan, charging my devices, and running an inverter. Your load demand will probably be less than mine. You could get away with a smaller battery and panel, but the price difference of going bigger really isn't going to be that much. My system cost me around $250-300 Canadian for everything.
    DoorDing likes this.
  9. Dec 31, 2015 at 6:57 PM
    #5509
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks a bunch guys, really appreciated it. Really like the multiple switch idea for keeping the draw low.
    Trying to keep everything on the cheap but still keep it reliable. Usually the two don't go together but trying. All of this information will help a bunch.
  10. Dec 31, 2015 at 7:51 PM
    #5510
    Leppz
    Vancouver, BC
    The battery is going to be the most expensive component. You can get a small solar panel and charge controller for less than $100 CAN.
  11. Dec 31, 2015 at 8:49 PM
    #5511
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah that's what I have found based on my search on Amazon.
  12. Dec 31, 2015 at 11:02 PM
    #5512
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    a couple of 12V 20Amp Hour Gel cells will work for you, but getting a marine battery is just as expensive and will have way more capacity than you will need. You can put the battery into a Styrofoam lined plywood box, for shielding from cold temps. The charging action will mildly warm the battery up, and the insulated box will retain some of that heat. That's what is done with the big wet cells for a radio repeater site on a mountain top. Expect only 30-50% output from the solar cell rating, given cloudy days, and of course the # of daylight hours. I'd use at least a 15W solar cell. Yes, you can get away without a solar charge controller, if your panel is 10Watts or less.
    scocar, tacoma16 and DoorDing like this.
  13. Jan 1, 2016 at 5:42 AM
    #5513
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks a bunch, lots of great info. Although the marine batteries are expensive we have some laying around at our farm so we will just repurpose them. If they are too old and not working very well I will look into those hour gell cells as an other alternative.
    I was aware of the efficiency drop on cloudy days but wasn't of aware of how much. I will look into atleast a 15w panel. Thanks for that.
    Awesome idea on the styrofoam box, will define rely be using that. We are also putting the battery on a shelf as well. Wiring will be as short as possible to keep everything as efficient as possible.
    :cheers:
  14. Jan 5, 2016 at 8:19 AM
    #5514
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    All of that ^^ is why I love this place. :thumbsup:
  15. Jan 5, 2016 at 8:31 AM
    #5515
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    May also want to think about a trickle charger for the items that are in the containers. It would suck for one of the items in the back to get a weak or dead battery .
  16. Jan 5, 2016 at 2:13 PM
    #5516
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I know right :cheers:
    Absolutely. Don't think we would have enough charge from the panels to go about it. May have to just bump start or boost with another vehicle. Atleast with the lights you can see what you're doing.
    Got 3 15w panels with charge controllers. Ordered two blue sea fuse panels and more led strip lights. We decided to do the hunting cabin as well. So in total 2 40ft shipping containers and a cabin will be lighted with solar power and Leds. This project is growing....
  17. Jan 5, 2016 at 2:17 PM
    #5517
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    :popcorn: Just came across this thread. I'm in.
  18. Jan 5, 2016 at 2:28 PM
    #5518
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    Our first trip of the year last weekend :cool:
  19. Jan 5, 2016 at 4:07 PM
    #5519
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    ricphoto and Chipskip like this.
  20. Jan 6, 2016 at 8:14 AM
    #5520
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Those are a good bang for the buck. Wish I would have scene them prior to receiving my panels. Even on the Amazon.ca they are very well priced. Close to $300CDN for the same thing, which is still cheaper $/watt than what I bought, three 15watt panels with there own 7amp charge controllers $220 taxes and shipped. hopefully it works.
