Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Jun 17, 2016 at 2:44 PM
    #6721
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    You're running the 5lb tank? Approx. how much did you burn through? Iv'e been looking at the propane fire as an alternative as well! Thanks for the info @1MK
  2. Jun 17, 2016 at 2:47 PM
    #6722
    scocar
    scocar Patron of the Farts
    Yeah, I don't nuke in plastic, and only dishwash top shelf. But I did have one leak on my in my work bag the other day, and the cause was a broken lock hinge, just plum wore out.
  3. Jun 17, 2016 at 2:51 PM
    #6723
    1MK
    1MK Desert Explorer
    Southern California
    I haven't measured the tank after use. I'll get a answer for you over the weekend though.
  4. Jun 17, 2016 at 2:58 PM
    #6724
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Hey speaking of bears.... I'm headed on a 10 day trip soon and definitely in grizzly country. Nothing new there I usually put my coolers off to the side and make sure there's nothing in the truck, I rather have to replace the cooler than my truck. Any of you guys have any other tips ? I've never had a problem before but never hurts to be more prepared
  5. Jun 17, 2016 at 3:21 PM
    #6725
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I'd love to hear from you guys regarding this as well. I'll be heading up into the front range in July and August, and I'm a newb when it comes to accounting for bears. Being born and raised a desert rat did me no favors in that regard.
  6. Jun 17, 2016 at 7:14 PM
    #6726
    1MK
    1MK Desert Explorer
    Southern California
    Getting back to you. Same tank directly from the last trip using 2 different gauges.
    Like I said, about 3 to 3½ hours on medium flame. Only one test result so far. I honestly feel like it should have used more?
    YotaDan and stroM-[QUOTED] like this.
  7. Jun 19, 2016 at 1:08 AM
    #6727
    Leppz
    Leppz Well-Known Member
    Vancouver, BC
    2014 DCLB Sport Premium
    Store everything in air-tight containers. Do not cook right next to your tent as the odours can linger on the tent fabric and attract bears. Do not wash dishes in your camp and drain your waste water away from your camp and away from any water source. If you have a BBQ make sure to set that up far away from where you are sleeping. From my experience that's the first thing bears go after for obvious reasons.
    While some people like to store food and coolers away from their vehicles unless you are suspending it from two trees or placing it in a bear bin I think it's best to just store it in your truck. If you're at a rec site with a large wooden picnic table you can always slid your cooler underneath it at the end of the night. Makes it a little harder to mess with.
    I have a 12v fridge in my truck. We try to bring pre-packed vacuum sealed meat, and if not we make sure everything is either zip locked or in plastic or glass airtight containers or both zip locked and inside a container. The fridge also has a decent seal and the truck helps block some of the smell as well. I sleep in the back of my truck and always have the bear spray and an air horn on hand. If I hear anything outside I'll blown the horn and get out with the bear spray and grab my axe. Make sure you have your truck keys on hand as well as you can always just hit the panic button on your fob and that usually does the trick. It's also good to carry some road flares or some fireworks/fire crackers with you to scare bears away if you don't own a gun.
  8. Jun 19, 2016 at 7:41 AM
    #6728
    jubei
    NoCo
    Stuff. Also things.
    Thanks for this, Ryan.
    That is a very detailed post, and exactly what I was looking for!
    Leppz[QUOTED] likes this.
  9. Jun 19, 2016 at 11:38 AM
    #6729
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    soup container with the screw on lid works amazing for anything liquid. I prefer to use it as a freezer and my cooler as an ice box to thaw
    dtaco06 likes this.
  10. Jun 21, 2016 at 10:38 AM
    #6730
    CascadesTacoma
    CascadesTacoma Well-Known Member
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    Three pictures of the new shower/faucet setup in the back of the truck. Everything can come in and out of the truck easily while the battery leads to the engine compartment stay in the little cubby.
  11. Jun 22, 2016 at 8:03 AM
    #6731
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    In Badlands SD
    BigOly, Jeremy M., YotaDan and 15 others like this.
  12. Jun 22, 2016 at 6:30 PM
    #6732
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    My background is from backcountry multi-day hike in camping. When it says do not cook right next to your tent, "right next" means within 100 yards.
    Add to that, do not under any circumstances, take food/snacks with you to where you are sleeping. Do not pack your toiletries into where you are sleeping, as those smells are also enticing. Besides reducing the likelihood of attracting/creating the occasional to rare bear encounter, it will keep the constant threat of local rodents (mice, packrats, squirrels) away from damaging your gear (tent/sleeping bag) and contaminating your food supply with their feces and urine.
    scocar, jubei and forty2 like this.
  13. Jun 22, 2016 at 7:35 PM
    #6733
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Custer State Park SD
    BigOly, VE7OSR, DaveEli and 8 others like this.
  14. Jun 22, 2016 at 7:41 PM
    #6734
    jubei
    NoCo
    Stuff. Also things.
    Thanks for the info, Rob! Good stuff!
  15. Jun 22, 2016 at 7:58 PM
    #6735
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Do camp 5!! It's up in the northern hills by Galena.
    FIRE74[QUOTED] likes this.
  16. Jun 22, 2016 at 8:09 PM
    #6736
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    I'll be in rocky mountain NP tomorrow night then badlands Rushmore area for weekend time frame. Then off to Yellowstone Tetons and glacier before heading to Oregon coast. Anyone in those areas let me know. Would appreciate any insider info and or meet up.
    FIRE74 likes this.
  17. Jun 23, 2016 at 6:49 AM
    #6737
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Will see if we can get into Camp 5 today, thank you for the tip! :thumbsup:
    wildfyr3[QUOTED] likes this.
  18. Jun 23, 2016 at 6:55 AM
    #6738
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    Hopefully the water level isn't too high. When I went through July last year there was almost none. You might get to use your sliders unless you have a real good spotter.
  19. Jun 23, 2016 at 6:56 AM
    #6739
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Water levels a low here, they are in desperate need of rain, everything is very dry
  20. Jun 23, 2016 at 7:02 AM
    #6740
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    How do you keep the air from seeping around the lid in yours? I have the same container with a pressurized valve in it and i have air escaping from right around the lid. I'm thinking about sealing the lid on and just putting water through the hose.
