Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Sep 22, 2016 at 10:37 AM
    #7801
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Okay too tall. Yeah I wouldn't recommend modifying them.
    snowboard704 likes this.
  2. Sep 22, 2016 at 10:47 AM
    #7802
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Not a lot of easy options unfortunately. A few people run little foam bumps (daystar maybe?) that have a stud, and mount them to the frame so they hit more vertically.
    I've got super bumps on the rear LCA location. They just barely touch at ride height, hit sideways, and deflect under hard hits. Going to figure out something different this winter. I believe several people have had success trimming them.
    Was looking at the possibility of welding up a little mount of the frame so they hit further out on the arm like 2nd gens. After making that work, I feel like it would be easier to just make hydro bumps work.
    At that point, people usually say "it would be a waste on a stock arm," or "it'll never work," yet the naysayers have never tried it themselves. Try it out and let me know how it works so I can copy it this winter. :D
    TLDR: very little info on 1st gens compared to 2nds
    jubei, Crom and snowboard704[QUOTED] like this.
  3. Sep 22, 2016 at 10:51 AM
    #7803
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Guess ill have to fab up something, definitely will keep you posted when its done:thumbsup:
    BYJOSHCOOK likes this.
  4. Sep 22, 2016 at 10:53 AM
    #7804
    Squeaky Penguin
    Brett
    FWIW, my plans involve cutting off the factory sway bar mount and building some sort of 'bump pad' in that area. Just very limited on space.
  5. Sep 22, 2016 at 10:58 AM
    #7805
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea it’ll definitely be something of that nature. Possibly even hydro if I’m going all out with bump plate/mounting etc but well see what the budget allows
  6. Sep 22, 2016 at 11:00 AM
    #7806
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    If it were me I wouldn't tell them you know.
    Crom likes this.
  7. Sep 22, 2016 at 1:21 PM
    #7807
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
  8. Sep 22, 2016 at 1:40 PM
    #7808
    1MK
    1MK Desert Explorer
    Southern California
    Sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo........
    Got the driveshaft back today. When I spoke to them on Tuesday they mentioned that an aftermarket midship stub was used and that's what broke. They've "never seen that happen before". I mentioned that I wouldn't have a problem paying the difference to upgrade to heavier duty components but they said it was the largest that's available before having to customize the whole driveshaft, carrier bearing and crossmember. Mentioned they were going to use a factory Toyota front shaft that they had laying around and make that work since it may be heat-treated and stronger then what they are able to get a hold of.
    They dropped it off this morning, no charge, and sure enough it looks like a factory front shaft as well as a new carrier bearing. But now knowing there was a size difference on the splined pieces I decided to tear it apart before installing it on the truck to make sure it look beefier. Same shit. The factory driveshaft that came in the truck is 26 spline, the last one that broke and this current one is 23 spline with a noticeable difference in diameter. Maybe it's stronger? Maybe it's the same? I really don't care as I've lost all trust in the thing to be honest.
    At this point I'm thinking of taking the truck to another driveline shop for a second opinion and possibly upgrading it if possible.
    Oceanside Driveline was great with the customer service: sincere, eager the find a solution and turn around time. But having never had a driveline failure before and being back with the same size parts puts a bad stigma on the thing.
    stroM- and adanfon like this.
  9. Sep 22, 2016 at 6:29 PM
    #7809
    G.T.
    G.T.
    CONUS
    Get your money back and spend it with someone who can count to 26.
    mpm, cmack, Acerwin and 2 others like this.
  10. Sep 22, 2016 at 6:45 PM
    #7810
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Haha, I spit out beer haha
    cmack likes this.
  11. Sep 22, 2016 at 8:53 PM
    #7811
    Crom
    Nick
    San Diego, CA
    Millions
    @1MK I'd for sure get a second opinion. Thx for sharing your experience.
    My Tacoma is currently FWD too. I'm getting the DS rebuilt by local shop... All new stock components going in... Only came out to get worn CB replaced.
    The guy rebuilding it won't let me modify it in any way lol. Said he owns 7 Toyota's. :). Been doing DS work for 40 years. Haha
    Acerwin, 1MK[QUOTED] and Jim Bob like this.
  12. Sep 26, 2016 at 11:30 PM
    #7812
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
  13. Sep 27, 2016 at 6:17 AM
    #7813
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Anybody on here have a 5th gen 4runner they want to buy a roof rack for? My frontrunner is too tall to fit under parking structures in LA. Kinda hard to go to work when you can't fit in the door... I'm going to take it off soon and swap it for a relentless rack. Losing 2.5 to 3 inches in height will be nice. FrontRunner makes a mean rack though.
    Probably also selling my 40" lightbar if that interests anybody.
    On another note, am I expo yet??
    @ProForce I'll be all over that water system when I have some more cash coming my way.
    YotaDan and Tim801 like this.
  14. Sep 27, 2016 at 6:51 AM
    #7814
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I dinged my drives haft inarch and the u joint went on by July. I found a used one to swap in but jus dropped mine off at a local shop @Night Eagle used for his. Leo did you use spicer/dana u joints? They recommended some other brand but I'm about to call then for the estimate
  15. Sep 27, 2016 at 7:06 AM
    #7815
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Spicer 1330x or gtfo
    Crom likes this.
  16. Sep 27, 2016 at 7:13 AM
    #7816
    odomandr
    Andy
    Fort Collins, CO
    They want to put neapco brand as it is the last "US made u joint supplier" 3 new joints and thicker diameter tube. Quoted 650 . I asked for a quote rebuilt back to factory waiting on a call back
  17. Sep 27, 2016 at 8:30 AM
    #7817
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Who are you using?
  18. Sep 27, 2016 at 10:47 AM
    #7818
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Who are you having do yours?
  19. Sep 27, 2016 at 11:58 AM
    #7819
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Anyone heading to the Vermont Overland Rally this weekend?
  20. Sep 27, 2016 at 12:18 PM
    #7820
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I think if I leave now I can make it
    Bentrodder likes this.
