Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Oct 22, 2017 at 6:02 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    This is what I was thinking. The fender is definitely being pushed out though.
  2. Oct 22, 2017 at 6:07 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Use a small level and a carpenter's square... compare it to the other side. Should help you at least focus in on where the problem is originating.
    Is the cap deformed..? cracked..? Wider gap in rear window on the top, bottom, other side..?
    You'll figure it out. My money is on that bed stiffener you installed... bet it's not square and when you tightened it down it pulled things outta whack, or you loosened some bolts and the fender 'dropped' while you were tinkering. Check both stiffener brackets, heat that fuker up and beat it with a hammer 'til it's 89 degrees
  3. Oct 22, 2017 at 6:13 PM
    MNMLST
    Earth
    and... get it done before the ice and snow comes or you'll bust the tail light or mess up the seals and get water, condensate, ice, shit inside the light which will start rotting things out in there..
    tacoma16[QUOTED] likes this.
  4. Oct 22, 2017 at 7:57 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m thinking the fender bent. Was Offroad and had a few bounces. I’ll remove the tail light and go from there. The sheet metal is deformed. The stiffener is in the right place. All on the passenger side where the sheet metal was slightly bent before. The cap window isn’t slowing as well though as the fender did push out. May get some ratchet strap in there and check for cracks.
  5. Oct 22, 2017 at 9:30 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Your entire bedside is giving way. You can see the wrinkle right above the top tail light bolt. I'd like to see a picture of your the entire truck to see what kind of load you are carrying. The bedsides are notoriously weak but that is an unusual place for it to be deforming.
  6. Oct 22, 2017 at 9:39 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Didn’t think I was carrying a crazy amount. Have the rtt, cap, and rack. The tool box has some switches, a small propane tank but that’s it. Nothing crazy for what a tool box could be holding.
    MotoEd likes this.
  7. Oct 22, 2017 at 9:43 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    I wouldn't think that is too much either. What does the other side look like? You can measure from the bed up to the top of the bed rail on both sides and maybe on another similar truck.
  8. Oct 22, 2017 at 9:51 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’ll measure but the total chaos stiffeners haven’t moved. Just the sheet metal behind it which makes me think it’s the bed rail/bed step that makes up the fender that is bent
    Tailgate still opens too.
  9. Oct 23, 2017 at 7:26 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
  10. Oct 23, 2017 at 8:34 PM
    G.T.
    G.T.
    CONUS
    So good to see you finally getting to enjoy it again @Zam15
    Crom likes this.
  11. Oct 23, 2017 at 8:45 PM
    Zam15
    Derek
    San Diego
    Needs power..
    ARMOR
    Those are pre current build shots. Hopefully I'll be able to hit up even better locations soon!
    G.T.[QUOTED] likes this.
  12. Oct 23, 2017 at 9:30 PM
    dbrfan
    dbrfan Well-Known Member
    2015 DCSB 4x4 6SPD
    I have a similar setup with similar issue. It hasn't moved that much yet, but edge of tailgate to Light is approximately .4", which is much wider than at the bottom where tailgate hinge is.
  13. Oct 24, 2017 at 5:03 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    happy Im not alone. This was before the bed stiffeners
    and after
    but it has opened up a lot more....
    At this point to change up to a new fender, lighter cap, and new rack setup, and maybe a drawer setup as I wont have the tool boxes in the windoor of the cap I am close to the cost of a flat bed from UTE LTD....
    Im going to see how bad the bed gets and kinda go from there. Knowing I can get a complete flatbed with crossbars for like $2500 US plus shipping and what not isn't too crazy considering that the cost of switching my setup will be very close to that and I still have the weak bed. See how she goes.
    Toyko Joe likes this.
  14. Oct 24, 2017 at 10:21 AM
    Chaser88
    Chaser88 Active Member
    Nelson, BC
  15. Oct 24, 2017 at 12:47 PM
    BillBraski
    BillBraski Potato
    VA Tidewater Area
    2017 White TRD Off Road
    Tacoma Tailgate Lettering LED interior lights
    You folks that have aftermarket front bumpers and are required to have front license plates, Whats your solve?
  16. Oct 24, 2017 at 12:55 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Some are built with mounting points. Pelfreybilt has them.
    oni06 likes this.
  17. Oct 24, 2017 at 1:16 PM
    G.T.
    G.T.
    CONUS
    Stuffed it under the front passenger floor mat and don’t drive like a retard.
    dskakie, Digiratus, dtaco06 and 2 others like this.
  18. Oct 24, 2017 at 1:20 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    No winch yet so I drilled 2 extra holes in the plate and mounted it to the fairlead holes
  19. Oct 24, 2017 at 1:44 PM
    tdubd
    tdubd Well-Known Member
    Todd
    Grand Junction CO
    07 party mobile
    ready for adventure
    Mine is on the lower half of my bumper underneath my fairlead, mostly covered in overspray haha!
  20. Oct 24, 2017 at 2:01 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    I live in CA and don't have a front plate on any of my vehicles. Only once in over 20 years did I get a fix-it ticket. I put the front plate on, had it signed off, paid a $15 fee then took it off again.
    Jim Bob likes this.
