Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Mar 27, 2018 at 11:50 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    RTIC is having a sale. Debating which size cooler is better. I mainly travel with just one other person. Would a 45 be good or 65? Trips from weekends to maybe 5 days.
  2. Mar 28, 2018 at 12:39 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I have the 65. Get the divider. You can put frozen goods with dry ice in one side and put refrigerated in the other.
    chowwwww and Drainbung like this.
  3. Mar 29, 2018 at 8:21 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Well. Over landing sometimes involves travelling large distances and staying in the seat for long hours right? My single cab bench seat sucks big time. What if I find a couple of good seats that water and dirt won't hurt, and then for a center console, find the smallest fridge freezer they make? Is that feasible??
    Adventurer_Alex likes this.
  4. Mar 29, 2018 at 8:27 AM
    overado
    overado Well-Known Member
    2010 RegCab Tacoma
    Lifted, 285/70/17s, Referbished FJ rims, custom front bumper, snorkel
    Sure is!...biggest issue is the wiring and such for the airbags and seat belts I swapped my bench seat for tacoma buckets and still need to fab up a console of some sort but my lunch cooler fits pretty good so I'm in no rush. Night and day the sitability for a long trek though!
  5. Mar 29, 2018 at 8:51 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Contact Metal Tech and see if they can help. They have a kit for FJs using prp seats that comes with a harness to retain front airbag / side airbag functionality.
    DoorDing likes this.
  6. Mar 29, 2018 at 9:08 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Hit up @stroM-. He put a small snowmaster fridge as his center console.
  7. Mar 29, 2018 at 9:17 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    You can also try something like my setup. Has been working great since I did it.
    Bed Slides on the Cheap
    https://www.tacomaworld.com/threads...ld-and-adventures.484602/page-9#post-15919993
  8. Mar 29, 2018 at 9:33 AM
    Nomad_Pilot
    Clay
    Ft Collins
    What about durable seats that rain and mud won't hurt. Sometimes I like to cruise with no doors
  9. Mar 29, 2018 at 9:38 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Neoprene seat covers might be the best option there unless you can find an aftermarket seat company that will use neoprene as the seating material
  10. Mar 29, 2018 at 12:34 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Corbeaus.
    Adventurer_Alex and Trailbutter like this.
  11. Mar 29, 2018 at 7:04 PM
    Train
    Train Loco with a motive
    Train
    N46°24'54" W81°01'48"
    2013 -Tacoma access cab 4x4
    Chop chop chop weld
    DSC_0306.jpg DSC_0278.jpg DSC_0328.jpg OXX BOXX
    rob1208, samiam, KRAMERICA and 2 others like this.
  12. Mar 29, 2018 at 7:13 PM
    Train
    Train
    Chop chop chop weld
    heating blanket is key in cold weather
  13. Mar 29, 2018 at 7:46 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Ive looked into this. They make one that runs off of USB and can be plugged into a portable battery meant for charging phones.
    Now that winter is over on the east coast, it moved down on my priority list, but its still good when I find myself in my 0 degree bag, and still cold
    Trailbutter likes this.
  14. Mar 29, 2018 at 7:55 PM
    Nomad_Pilot
    Clay
    Ft Collins
    Soooo you pulled your seat to make room for a fridge?
    Train likes this.
  15. Mar 29, 2018 at 8:36 PM
    Trailbutter
    Trailbutter "Percussive persuasion = perfect fit"
    South East VT/ South coast MA
    2011 Black DCSB
    FOX/TOYTEC suspension RCI sliders Bud Built skids Pope overland RTT
    I can now say I witnessed a human remove there seat for a fridge of what I hope is beer. I tip my hat to you sir. :hattip:
  16. Mar 29, 2018 at 8:38 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Man does seem to have his priorities in order!
    Train, dtaco06, samiam and 1 other person like this.
  17. Mar 29, 2018 at 8:40 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A fridge of beer and a coffee maker for the morning. Priorities are in the right place.
    Train, jubei, samiam and 2 others like this.
  18. Mar 29, 2018 at 8:54 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Any trouble running the OXX on the stock inverter?
    Train[QUOTED] likes this.
  19. Mar 30, 2018 at 10:28 AM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    No room for the ladies. Dislike.
  20. Mar 30, 2018 at 10:58 AM
    Nomad_Pilot
    Clay
    Ft Collins
    Well I took the plunge. I went to Toyota dealership yesterday and I have them looking for a brand new v6 manual transmission access cab trd in white.
    dtaco06, DoorDing, Drainbung and 2 others like this.
