Car Camping / Trip Reports / Photos / Buildouts / “Overland” / Expedition Rigs Area (homeless?)
Discussion in 'Off-Roading & Trails' started by BuzzardsGottaEat, May 16, 2012.
  1. Jan 2, 2014 at 7:59 PM
    #1841
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I found a bin called "very good box" or something that fits perfectly. I just need to get 3 more. Carpeting is high on my list along with some kind of organizer for my back seat area and rock sliders.
  2. Jan 2, 2014 at 8:09 PM
    #1842
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    The Bogert Group makes some great stuff. Once I figured out that I could put my hi lift in the factory jack spot of my AC ;)
    I purchased their Safe Jack Stabilizer for it.
    I could see owning the Bottle Jack kit too. Great choice.
  3. Jan 2, 2014 at 8:13 PM
    #1843
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Mossberg 500 w/short barrel fits perfectly down there, too..[​IMG]
  4. Jan 2, 2014 at 8:33 PM
    #1844
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Noted and archived for future reference. :-D
  5. Jan 2, 2014 at 8:38 PM
    #1845
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I like that a lot but I bet the scrap pieces of wood that I keep in the bed for this purpose were a lot cheaper. :p
  6. Jan 3, 2014 at 12:22 AM
    #1846
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    hahaha that's where unused to keep my shot gun for a while ahhaha :p
    nice that looks good under there like that
    I used to do that but 3 pieces of 4x4s on not so solid ground with the factory shitty jack= sketchy situation :(. Now I can go to anything to lift my truck the frame, a LCA , axel, or sliders in the future safely
  7. Jan 3, 2014 at 3:09 AM
    #1847
    Cold Iron
    Mn.
    2013 AC T|X Baja
    How to fit a Joel Etchen Guns custom combo with EELL wood, B. Rizzini, Benelli Ultralight or pretty much anything else you own
    I still carry some dimensional lumber with me when I know I'm going off road. But it is not my first choice to use. A rock under it or even a bump in the Canadian Shelf will split it faster than a hydraulic wood splitter once you get pressure on it. But it has saved my butt more than once. And also damn near given me a heart attack.
  8. Jan 3, 2014 at 8:03 AM
    #1848
    otis24
    Mark
    California
    I'll definitely keep that in mind. I've been putting a blanket over the wood to keep my thermarest sleeping pad from either getting a splinter or getting pinched in the space between the wood.
  9. Jan 3, 2014 at 9:01 PM
    #1849
    uscg2008
    coby
    When I had mine like that I just bolted straight through the bed and used a large washer and nut. Just be carefull when you drill.
  10. Jan 4, 2014 at 9:22 PM
    #1850
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    http://youtu.be/PcGTHw7dGeU
    Think a rear winch is in my future..
    Drove onto what was a frozen stream; totally gave way as soon as the front end got off of the bank. Good stuck.
    Rigged a self recover from the rear, then a friend showed up. Decided to do the safer option and have him get me unstuck.
    Tried winching; he started sliding.
    Instead of rigging an anchor on him, decided to give my snatch strap a shot.
    It worked.
    Think a rear winch may be in the future. Or at least fabricate a Pull-Pal.
    Enjoy.
  11. Jan 4, 2014 at 9:28 PM
    #1851
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    There may be something wrong with the link...
  12. Jan 4, 2014 at 9:30 PM
    #1852
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Hmm.. working for me.
  13. Jan 4, 2014 at 9:31 PM
    #1853
    tacodane
    Dane
    Strange. Every time I click the link it says server lost. I'll restart my phone and see
    Update. Video worked
  14. Jan 4, 2014 at 9:46 PM
    #1854
    skygear
    skygear                    
    Thank you. I have just the telescoping pole for this idea. Originally it was going to be for 'security' - a camera. But can make it multi purpose. Especially with the height I can get on it/
  15. Jan 4, 2014 at 11:19 PM
    #1855
    uscg2008
    coby
    Oh jake :rolleyes:
  16. Jan 5, 2014 at 12:49 AM
    #1856
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    What do you fellas use for strong weatherproof containers? I have lots of actionpackers but they are a little flimsy. They bulge and the lids can take off on their own(almost too out 2 bikers). Pelican cases are too expensive. I think if the container is more expensive than the contents, the case may be too expensive.
    Any ideas?
  17. Jan 5, 2014 at 2:58 AM
    #1857
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Surplus Hardigg cases.
  18. Jan 5, 2014 at 5:30 AM
    #1858
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    You should be able to locate some second hand pelican cases. Lotta excess after 13 years of combat in two theaters. If the hinges and latches are good, at most you may have to install a new gasket or possibly the breather.
  19. Jan 5, 2014 at 7:34 AM
    #1859
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    These look interesting..
    http://shop.sportsmansguide.com/net/cb/cb.aspx?a=1537715
    It's worth a shot; especially at that price. I've got a hard time rationalizing dropping $500 + on Pelican cases, and really don't like the idea of putting them on a rack up in the air. Too much weight up high.
    Picked up a few big Sealine Dry Bags, they've been working great for me. Plus, when they're empty, they can be stored much easier..
  20. Jan 5, 2014 at 7:44 AM
    #1860
    skygear
    skygear                    
    craigslist, government auctions, ebay, search for "hardcase"
