Car Care Nut video on the 2GR-FE 3.5L V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crooked Beat, Nov 5, 2022.
  1. Nov 7, 2022 at 12:45 AM
    #61
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Smartest guy in the room, tough guy, paranoid and thin skin. What a winning combination.
    bulalo, Hooper89 and KY_Rob like this.
  2. Nov 7, 2022 at 1:07 AM
    #62
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Damn, and here I have been blaming those oil puddles on my 23 year old S10.
    Hooper89 and zoo truck[QUOTED] like this.
  3. Nov 7, 2022 at 4:39 AM
    #63
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i enjoyed the video and learned something. thanks for posting.
    do i trust engineers to do it right, the first time, all the time? absolutely not. most engineers i worked with understood theory as you would expect but knew very little about the actual use and how-to maintain.
    in a prior career i worked for a few companies that manufactured complex equipment and then followed it to the field to install, start-up, and train customers on the operation and maintenance.
    many times the initial engineering was a cluster **ck, and i was forced to make modifications to get it to fit the application and function properly.
    i see similar issues with the tacoma and suspect the cause is similar as well.
    if other manufacturer's designed and built some of the F-ups that the turd gen Tacoma is known for, many on here would call them out. the routing of the exhaust pipe is a perfect example. what some refer to as 'mods' are actually aftermarket improvements because of toyota's poor engineering and design.
    KY_Rob likes this.
  4. Nov 7, 2022 at 5:17 AM
    #64
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    I'll take a well experienced and trained tech.
    Unlike an engineer, a well trained and experienced tech, has actually seen the bumbles and mistakes that the engineers made up close and personal, and instead of theorizing or how they should work and scratching their head as to why this is happening. A tech just makes it work and fixes it.
    bulalo, Johnny919, KY_Rob and 4 others like this.
  5. Nov 7, 2022 at 5:18 AM
    #65
    jaxyaks
    Bully pulpit huh?.....it is an optional you tube channel you can choose to watch or not...I would hardly call that a bully pulpit.
    JSB10, bulalo, Johnny919 and 2 others like this.
  6. Nov 7, 2022 at 5:33 AM
    #66
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    While not mutually exclusive, these statements definitely stand to contradict each other. You blindly trust engineers, yet engineers and techs that put themselves on a pedestal are untrustworthy?
    As an engineer with experience in product development (albeit a different industry), there’s no room for ego. Learn what you can from your mentors and fellow engineers, but don’t take for granted the tech that has seen the product of your mentor’s design in real world application far more often and for longer than any testing had exposed the engineer to.
    Saluki22, KY_Rob and mquibble like this.
  7. Nov 7, 2022 at 5:51 AM
    #67
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'm thinking taco god made that video sometime back. Hopefully toyota has fixed that timing cover oil leak issue by now.:fingerscrossed: Even my old gen1 tundra at 19 years and 300k miles never leaked a drop of oil.....well engine oil that is. Steering rack was another issue.
  8. Nov 7, 2022 at 5:59 AM
    #68
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I'll just treat my tacoma like an old chevy, regular dino oil and some of that stop leaking additive stuff every now and then.
  9. Nov 7, 2022 at 6:00 AM
    #69
    zoo truck
    None
    I've worked with engineers. Generally the senior ones get it right the first time. When it goes to the bean counters in the front office thats where stuff can go wrong. Having a good tech in these cases is priceless. I knew a ford tech at a nearby dealership, now retired that made their automatics work better than the engineers at ford designed them to by altering, and adding parts to them.
  10. Nov 7, 2022 at 6:18 AM
    #70
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    As long as you're putting in new oil and putting in the correct amount along with whatever weight rating it says in the engine bay you are fine which is what he said in the video I posted. He even says the toyota oil is the same as mobil one.
    Any new oil is better than no oil or having old oil. Doesn't matter what brand it is.
    grogorat, KY_Rob and mquibble like this.
  11. Nov 7, 2022 at 6:24 AM
    #71
    Johnny919
    Long Island, NY
    When I think about oil changes, it's not the quality of the oil I'm concerned about. I agree modern specd oil will last a while. The way most people drive doing alot of stop and go will wear out oil quicker. Also if someone doesn't drive much, getting to that 10k interval seems like a while or if it's 1 year. Let alone if you're using the tacoma as a truck and hauling or towing.
  12. Nov 7, 2022 at 6:36 AM
    #72
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    So my redneck engineer in me wonders... since the exact area of the oil leak is identified in the video the OP posted, why not just clean the outside seam of the timing chain cover squeaky clean, and then dap a bit of JB Weld over it?
  13. Nov 7, 2022 at 6:51 AM
    #73
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You're making the same assumption of usage as that mechanic. We can only really speak for ourselves regarding usage.
    His recommendation for 5K OCIs is a catch-all and errs on the side of caution. He has no real data to back it up.
    I do agree with him on one point; it's your vehicle, do what you think is right for you.
  14. Nov 7, 2022 at 6:57 AM
    #74
    Hooper89
    It probably wouldn't stay there.
    What pisses me off is if you watch the video it's obviously a design defect in that every one of them leaks in the exact same spot. It should be a recall or an extended warranty but since Toyota is now 1980s GMC nope, just push the customer out the door and cross your fingers his engine doesn't leak or his paint doesn't fall off within the first 36k miles.
  15. Nov 7, 2022 at 7:12 AM
    #75
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I read someone in here did it and was successful. No longer have any leaks
    shotgunbilly420 likes this.
  16. Nov 7, 2022 at 7:28 AM
    #76
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Or just feel sorry for yourself lol . You need it :rofl:
    shotgunbilly420 and mquibble like this.
  17. Nov 7, 2022 at 7:38 AM
    #77
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Y’all wana know why I don’t fully trust engineers? Just go look at all the issues on the new tundras.
    electronic control waste gates with stamped steel that holds the rod can be a cunt hair off and cause total failure of the waste gate? Nice
  18. Nov 7, 2022 at 7:51 AM
    #78
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Engineers on forums are the worse. Just because they have an engineering degree (that they love to tell everyone about) means they must be the resident expert. Their engineering degree could be completely different then then topic being discussed but still claim to be 100% correct with clearly the wrong answers.
  19. Nov 7, 2022 at 7:59 AM
    #79
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    Us engineers are definitely not perfect. The owners manual and maintenance guide are written by the marketing department. Engineers make recommendations, but the final decisions on what gets printed is NOT engineering.
    Hooper89 and mquibble like this.
  20. Nov 7, 2022 at 8:01 AM
    #80
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Engineers and mechs both get it wrong sometimes. Take what you learn from both and make your own educated decision based on your usage and willingness for risk.
    And don't trash anyone else for THEIR decision.
