Car Care Nut video on the 2GR-FE 3.5L V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crooked Beat, Nov 5, 2022.
  1. Nov 9, 2022 at 7:52 AM
    #121
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    My wife’s car is a 2011 v6 Rav4 and it takes 5w-30. You already see the intervals - 10k assuming synthetic.
    Hooper89 and zoo truck like this.
  2. Nov 9, 2022 at 8:00 AM
    #122
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think if one as a lick of commonsense and can hold a wrench without getting injured can change their own oil, or do simple auto maintenance.
    Hooper89 likes this.
  3. Nov 9, 2022 at 8:06 AM
    #123
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You can only infer it from your experience and perceived observations. Do you have any direct proof or knowledge?
    I see you have an '05; I'll assume you have an auto. Let me ask you this....
    How often do you change your ATF?
    100K per Toyota's original interval?
    60K per Toyota's new interval?
    12.5K/2 year per Aisin's recommendation?
    Other?
    Why?
  4. Nov 9, 2022 at 8:17 AM
    #124
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’ll answer that.
    I drain and refill my Tran fluid every 15k with approximately 4 qts. Why? Because it isn’t very costly.
    why do I change my oil every 5k miles? Same reason.
    why so much anger?
    stftaco likes this.
  5. Nov 9, 2022 at 8:25 AM
    #125
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    From experience, I've sat in on these kind of meetings as an engineer and I've changed the transmission fluid between 50 and 80k miles based on experience with other transmissions both in my personal vehicles and in industrial settings.
    Originally Toyota said this was lifetime transmission fluid, no fluid is lifetime.
    When companies started to recommend 10k mile changes people scoffed at that saying hell no, now people are resistant to it. Most of these engines back then were the same engine, they just changed what the manual said at the time. Same with the push to 0w oils, it was the same engine, just epa numbers required the change to a thinner oil for milage.
    If you just drive on the highway all the time 10k is probably fine, but if you do stop and go city driving you should rethink that
    I change my oil between 5 and 7k miles, having seen pictures of the insides of other 1gr engines with 10k mile changes and the inside of mine ill stay with more frequent changes.
    I would wager that these recommendations are based on a 150k-200k miles expected lifetime average for these engines. That's a fair estimation for use but if you want to keep your truck longer then you will need to adjust accordingly.
    My original point is, people that say the engineers said do this do not realize it's not the engineers saying it.
  6. Nov 9, 2022 at 8:36 AM
    #126
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Gotcha, my mistake I read the 20 videos as he had only done 20 videos. I really had no point other than to point out that he had made more than 20 videos.
    splitbolt[QUOTED] likes this.
  7. Nov 9, 2022 at 8:41 AM
    #127
    splitbolt
    NW Arkansas
    So no actual direct knowledge? Just what you can infer and suppose from your experience and very limited sample size...not that there's anything wrong with that.
    I used the ATF example, to illustrate the disparity between 'penny piching' Toyota and Aisin upselling 'unnecessary' fluid intervals. Or, should we assume Aisin engineers are in the same camp as Toyota engineers and be changing our ATF at 7,500 miles/1 year? Just trying to see the consistency in your logic.
  8. Nov 9, 2022 at 8:44 AM
    #128
    splitbolt
    NW Arkansas
    No worries:)
    I like a good argument, as long as there is something to be gained by either side; preferably both sides.
    Argument for argument's sake is unproductive.
  9. Nov 9, 2022 at 8:46 AM
    #129
    point45
    SoCal, OC
    05 DCSB TRD offroad
    No experience, just about 12 years working in industry as an engineer the last 5 dealing with transmissions and engines of some type and having been involved with these type of decisions and what gets put to print.
    You can do 10k oil changes all you like, but what a company recomends is not driven by engineering. As your atf example shows with your own thinking.
  10. Nov 9, 2022 at 8:53 AM
    #130
    splitbolt
    NW Arkansas
    You lost me here...
    How so?
  11. Nov 9, 2022 at 8:59 AM
    #131
    Gasper Goo
    Gasper Goo Active Member
    '23 MGM TRD OR
    Mobil1 beanie should arrive any day now...
    Z- "Look at the minnows darting between the rocks. Such is the happiness of fish"
    H- "You are not a fish. How can you know what makes fish happy?"
    Z- "You are not I. How can you know that I don't know what makes fish happy?"
  12. Nov 9, 2022 at 9:25 AM
    #132
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Yes, I know how to read. The person I quoted had a 2007 rav4 and in the image that was posted didn't clarify the year.
  13. Nov 9, 2022 at 9:31 AM
    #133
    point45
    SoCal, OC
    05 DCSB TRD offroad
    Your statement that their recommendations on atf changes are monetary.
  14. Nov 9, 2022 at 9:56 AM
    #134
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    I agree. And what about number of start cycles? Long idles? Short trips? Starts under very cold conditions? Time between starts under cold conditions. Do these factors impact oil quality? I would imagine they do. If the manufacturer recommends 10K, then I'm likely to be changing it between 5K-7K.
  15. Nov 9, 2022 at 12:27 PM
    #135
    splitbolt
    NW Arkansas
    I thought that was your position...
    Ultimately, what else is there?
  16. Nov 9, 2022 at 12:31 PM
    #136
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    5W-30 as I recall it. I also never used synthetic. Never burned a drop while '03 Acura would be down at least a quart at the 3K OCI.
  17. Nov 9, 2022 at 2:28 PM
    #137
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Here is an analysis showing 10k mile oil changes ... dude has been tracking it since new... check out how little crap is floating in it after 10k miles... as opposed to at the first 4k... Which is why the MAIN early oil change should be the first one... the subsequent seem quite fine at 10k.
    stftaco, ret42 and mquibble like this.
