car hauler towing
Discussion in 'Towing' started by grummyman, Dec 1, 2018.
  1. Dec 1, 2018 at 7:51 AM
    grummyman
    grummyman [OP] New Member
    joe
    I have several questions. I have a 2011 Tacoma V-6 with auto trans and tow package. I have 2 cars that I want to trailer to car shows ( only one at a time ) due to distance from home and gas mileage. I bought a Big Tex CH 70 18 ft car hauler weight 1975 lbs. the rat rod or the street rod 2600 lbs. at the most total weight 4700 lbs. this should not be a problem to tow from what I have read dose have electric brakes both axles and brake control wired in to factory wiring. In town drive in 4th gear ? and 5th on the highway
  2. Dec 1, 2018 at 8:45 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You should be ok as you are about 2000lbs under max tow capacity. You may want to do some things to make towing easier and smoother such as install air bags, a weight distributing hitch etc. Would not put it in D/5 while towing in the city or highway. While towing keep it in 4 and possibly down to 3 if you are climbing long grades, hills or mountains and the tranny is hunting gears.
    Watch your Gross vehicle weight max. Remember everything you add to the truck is included in that weight including trailer tongue weight, passengers, stuff in the bed of the truck and so on.
    You should be just fine.
  3. Dec 6, 2018 at 1:09 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard:hattip:. Tow in 4th and you should be fine with a WDH. Might want to monitor tranny temps too:thumbsup:
  4. Dec 6, 2018 at 8:04 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
