Car Idiot has Towing concerns (whimpers like school kid)
Discussion in '1st Gen. Tacomas (1995-2004)' started by DYoung, Dec 7, 2009.
  1. Dec 7, 2009 at 10:15 AM
    DYoung
    DYoung [OP] Member
    Built a schedule c pipe frame and 14 guage steel cap. Very tough.
    Hello Folks,
    Great forum, I am really glad I found it!
    Okay, so here's my thing. I have profound respect for car people...alas, its not my cup of tea (Im a blacksmith and furniture maker). So I could use some friendly guidance with a towing issue. I read this thread but it raised many questions in my mind.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
    I drive a 99 Tacoma, V6 (with the short extended cab)
    Right now I have a burly steel cap on the back that I custom made. Its a few hundred pounds. But Im notincing the rear of the truck is sagging....I suspect not from the cap but from previous hauls (lots of wood, cement etc)
    My goal:
    I am hoping to build an old fashioned post and beam (timber frame house) so I need to haul pretty long tree trunks.
    So Im hoping to buy a 14-17 foot trailer.
    The first questions are whether or not I can tow circa 5000 lbs.
    The second question is....what do I do, look for, buy, keep in mind, etc.:eek:
    Third question is....holy crap I have analysis paralysis. All this technical car stuff is freaking me out !!!!:cool:
    Can someone help me with a checklist of things I need to "look under the hood for" in order to even determine if I can haul that much weight/trailer?
    oh, if anyone needs metal working tips/advice, please let me know. I also build historical armour so sheet metal body work is pretty much up my alley.
    Thanks
    Drew
  2. Dec 7, 2009 at 10:43 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    How many logs at a time? you will want to factor in the total weight of everything. Whats the distance? The terrain?
    Might want to look into an AAL(add a leaf) to compensate for that sagging.
    I would definitely get a tandem axle trailer with trailer brakes, this well help distribute the load a little better and help you stop w/ the brakes. Whats your budget on a trailer? an all aluminum trailer is going to cost quite a bit more than the equivalent steel trailer and will help you tow a little bit more for your limited payload.
  3. Dec 7, 2009 at 11:21 AM
    DYoung
    DYoung [OP] Member
    Probably one tree 2-3 foot diameter trunk at a time. Doubtful any longer than 14 feet, hence a trailer of simlar length.
    I looked under my truck. Max gross haul weight for the hitch is 5000lbs.
    As for the engine, is it a question of liter size? Ie, what should I look for to determine the hauling guts of this truck other than knowing its a v6 ?
    Can 'after market' brakes be installed on a trailer?
  4. Dec 7, 2009 at 11:26 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if you are gonna be hauling heavier loads quite often I would look into the air lift assist for the rear of your truck. I know firestone makes a kit, they are adjustable so with however much weight you add you can add more or less air in the system to level out your truck.
  5. Dec 7, 2009 at 1:53 PM
    DYoung
    DYoung [OP] Member
    What about these http://www.truckspring.com/timbren_285.html
  6. Dec 7, 2009 at 6:47 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    if your truck is an automatic look into a transmission cooler - esp if you are making long hauls and/or hauls over steep terrain.
  7. Dec 7, 2009 at 6:59 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    all good suggestions what kind of trailer are you looking at buying i have found with a couple of mods boat trailers are great for hauling logs
  8. Dec 8, 2009 at 6:38 AM
    macgyver
    Brad
    Canton, GA
    Good idea. Never thought about that. Plus it would be a lot lighter since there is less metal.
  9. Dec 8, 2009 at 6:42 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
