Car Is Locked Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by P2skater1, Jun 6, 2018.
  1. Jun 6, 2018 at 12:11 AM
    P2skater1
    P2skater1 [OP] New Member
    Logan
    Tacoma
    Hi, I need to find a fix for my problem fast. I went out to my truck and tried to start it up, but the key physically wouldnt turn. The steering wheel wont turn, and i cant change the gear. I need help asap.
  2. Jun 6, 2018 at 12:17 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Is your battery drained?
    Is any of the electrical working?
  3. Jun 6, 2018 at 12:24 AM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Try holding the brake and turning the wheel when you try turning the key..
    BassAckwards and dome like this.
  4. Jun 6, 2018 at 12:30 AM
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    The key cylinder and steering lock assembly should be 100% mechanical. If the key won't physically turn it's either because a) the teeth on the key were damaged or the cylinder has somehow become damaged -- either way implying that the teeth of the key no longer align the pins in the cylinder to allow it to turn. Alternatively, it might not turn due to b) the steering lock is jamming it, which means the steering wheel is turned too far in one direction so try rotating the steering wheel a few degrees left or right before/while turning the key back and forth -- this might require some force on the steering wheel to rotate it off of the "jam". b is the most likely scenario.
    stbear likes this.
  5. Jun 6, 2018 at 12:44 AM
    P2skater1
    Logan
    Tacoma
    Open door light is on and seatbelt sensor beeps so its working.
  6. Jun 6, 2018 at 12:45 AM
    TireFire
    Olympic Peninsula
    Then try what others suggested
  7. Jun 6, 2018 at 12:52 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    An electrical issue would not prevent the key from rotating. Putting in the wrong key would. Sometimes. The steering lock mechanism and the ignition mechanism interefere with each other in my truck. I have to rotate the steering wheel back and forth to release what appears to be tension on the ignition to steering wheel lock mechanism.
  8. Jun 6, 2018 at 1:46 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    These are the answer.
    P2skater1[OP] likes this.
  9. Jun 6, 2018 at 2:27 AM
    P2skater1
    Logan
    Tacoma
    I fixed it, i turned the wheel right and held it and the key was able to turn. Thank you everyone.
    Alexely999 and Dennisi01 like this.
  10. Jun 6, 2018 at 4:29 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Once again TW saves the day, even in the wee hours of the morning!
    Alexely999 likes this.
  11. Jun 6, 2018 at 4:32 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    And welcome to tw. Quick answers
  12. Jun 6, 2018 at 4:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    It will happen again. Not that there is anything wrong, it just will. But don't think that 'right' is always the answer. Sometimes 'left' will be.
    Steering/ignition interlocks became common around the late 60's for all marques. So this isn't a 'new' issue, nor is it Toyota/Tacoma specific.
    Just pointing that out so you'll know you can apply the same technique when it happens to you in another vehicle. Generally a gentle tug is all that's required.
    NEVER force the key, or you could wind up immobile and in need of a locksmith.
    yorttam83 likes this.
