Car not full of gas, yet fuel pump keeps stopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Apr 9, 2017.
  1. Apr 9, 2017 at 12:23 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hi guys,
    It is worse than before... even when I move the fuel pump to replace it and change position, it keeps stopping like it is full but the tank is almost empty so it is not the problem.
    Do you think I can do something to fix it?
  2. Apr 9, 2017 at 12:34 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Check your evap canister? Usually when people refuel their cars/trucks and it stops on the first click some people tend to force more fuel into it which eventually goes into the evap canister damaging it. Don't know your year or history of your truck so can't say else you have done to the truck.
  3. Apr 9, 2017 at 12:35 PM
    bra
    Badges off
    Thanks,
    It's a 2008 TRD Sport 4X4 with 35000 miles on it
    Where is the evap canister situated?
  4. Apr 9, 2017 at 12:41 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    Do you mean the gas station pump? Or your trucks fuel pump?
    bra[OP] likes this.
  5. Apr 9, 2017 at 12:41 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    It's back at the gas tank
    bra[QUOTED][OP] likes this.
  6. Apr 9, 2017 at 12:59 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Have you tried another gas station or different pump at the same station? Every once in awhile you just a screwy pump. Also, are you pumping with the handle squeezed wide open or are you pumping slow. Again, some pumps are just screwy and kickoff easier if you're pumping at full flow. I always just set the lever on the first latch point. It doesn't take that much longer, and I almost never have a problem.
    I've also always filled past the first cut off and never had a problem with the evap. I fill to the 4th cut off which isn't even an extra gallon past the first cut off, but it's a habit now and don't plan on changing.
  7. Apr 9, 2017 at 5:47 PM
    bra
    Badges off
    Yes I tried different gas station of different brands and I think when I just purchased my Tacoma it didn't made that.
    Also yes I pump at full flow but it shouldn't be a problem normally
  8. Apr 9, 2017 at 5:51 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    If the tank isn't venting properly, it will make the pump kick off too soon.
    lowrange likes this.
  9. Apr 9, 2017 at 10:31 PM
    Awsomeo67
    Awsomeo67 Well-Known Member
    08 reg cab long bed
    I have that problem to, but only at random pumps at different stations. I found that if I pull the nozzle out a bit, like an inch, it all works like it supposed too. Im thinking that the tolerance between the nozzle and hole is way to close so the fumes cant escape causing the pump to think its full.
  10. Apr 10, 2017 at 2:04 PM
    2006whitetacoma
    2006whitetacoma Well-Known Member
    2006 White SR5
    I use to have an 01 RAV4, i stopped buying gas at the Amoco down the street because their pump constantly shut off on me. I noticed this problem with Pilot stations also. I think some stations just have pumps that don't like Toyotas for some reason.
