Car Play
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thumper06, Apr 28, 2021.
  1. Apr 28, 2021 at 10:21 AM
    Thumper06
    Thumper06 [OP] Active Member
    David
    Arizona
    06 Double Cab 4x4 TRD
    Rear Locker Differential, 3" Revtek Lift Kit, K&N Filter
    So I'm the proud owner of a new 2021 Taco which replaced my 2006 which I loved. This is my 1st vehicle with Car Play. I've search the threads for my particular problem but haven't found anything. I apologize in advance if it's out there somewhere.
    Here's my issue: about 1/2 the time my JBL Premium Sound system does not recognize my phone is connected or if it does, it's connected via bluetooth only even though I have a new lighting cable plugged it. I try unplugging and re-plugging but that doesn't work. I try waking my phone (Car Play is enabled when the phone is locked) but that doesn't work. I've tried connecting before I start the truck and after I start it, no difference. Usually I have to turn the truck off and restart it or switch my phone to airplane mode and then off and it will "sometimes" connect. Any ideas or do I need to visit my dealer?
  2. Apr 28, 2021 at 10:33 AM
    Shellshock
    Iowa
    Have you tried a different cable?
    Spanky3412 likes this.
  3. Apr 28, 2021 at 10:41 AM
    Thumper06
    David
    Arizona
    Well, that would be an obvious thing to try and no, I haven't because the one I'm using is brand new. But, point well taken, I will try a different cable. Thanks
  4. Apr 28, 2021 at 10:44 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Turn off your Bluetooth. Connect via cable. It could be prioritizing Bluetooth oner hard wire connections
    kite_325 likes this.
  5. Apr 28, 2021 at 10:45 AM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    Also CarPlay is picky about cables, try a cable from Apple (so not anker or anyone else).
    kite_325 and Spanky3412 like this.
  6. Apr 28, 2021 at 10:48 AM
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    I would definitely try using an apple cable just to eliminate that as the problem and make sure in the settings you are set for carplay and not android.
  7. Apr 28, 2021 at 10:50 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I try not to let the system confused, so I don't have my phone blue tooth paired with the system, and I only plug in via cable to the CarPlay usb port.
    So far 75% of the time it works with no issues. 10% of the time I just need to plug and unplug to get it to work, 15% of the time it's connected but no music playing, I have to turn the audio on and off just so that the music can start playing
    I have CarPlay on other vehicles too, it's definitely not 100% working every time. With enough plugging and unplugging, it eventually works. As far as having dealer to take a look, I wouldn't because I think there aren't many things they can do it's all software engineer's job fixing bugs at product development research centers.
  8. Apr 28, 2021 at 10:52 AM
    Ydog32
    Ydog32 Well-Known Member
    Wyatt
    2021 MGM DCLB TRD Sport 4x4
    OEM lift 2” front 1.5” rear, Black TRD Pro Grill,275/70 R17 KO2 Tires, Backflip Bak 4x Tonneau Cover, Mountain Hitch Tailgate Insert, Tint, 17" FN f(x) wheels.
    I have this issue in both my 2019 rav 4 and my 21 Tacoma. New apple cable fixed it.
  9. Apr 28, 2021 at 10:53 AM
    stay_tuned
    stay_tuned Limitations live only in our minds
    Bryan
    DMV
    2021 Tacoma OffRoad DCSB 6SPD BRM
    carplay def isnt the best with these vehicles, mine lags about 30 seconds to a minute before it gets to the point i can play music after ive plugged it in for the first time in a day. i can confirm it did work with anker and apple cable. also make sure youre not plugging in the center console because it wont work
  10. Apr 28, 2021 at 10:55 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    The first step in CarPlay connecting is the system disconnecting the bluetooth connection with the phone. Everything CarPlay related goes through the data cable.
  11. Apr 28, 2021 at 11:27 AM
    Thumper06
    David
    Arizona
    Thanks everyone, I will try another Apple lightning cable. I hope I don't have to disable bluetooth to use CarPlay, seems it ought to prioritize a cable connection over bluetooth but if all else fails, I'll try that too. It is set for Apple CarPlay and not android.
  12. Apr 28, 2021 at 11:30 AM
    Ydog32
    Wyatt
    Correction, I also had to disable Bluetooth and get a apple brand cord.
  13. May 3, 2021 at 12:15 PM
    Thumper06
    David
    Arizona
    Update. Seems if I disable bluetooth, my iPhone connects to CarPlay every time. It's a bit of a hassle but at least I have a work around. Thanks again.
