Car seat Hook removal ?
Discussion in 'Audio & Video' started by OldDog, Aug 12, 2011.
  1. Aug 12, 2011 at 12:19 PM
    OldDog
    OldDog [OP] Well-Known Member
    w.mass
    2010 reg cab 4X4
    I'm putting a sub box in my reg cab. Just wanted to know which is the best way to remove the car seat hook from the cross brace .
    Thanks
    olddog
  2. Aug 12, 2011 at 12:25 PM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Might I suggest designing the box to retain the hooks? I'd be pissed if I went and bought a used truck and found some dude removed them. Don't know as if I'd check for those before I'd roll off the lot.... Anyhow..... Good luck
  3. Aug 12, 2011 at 12:28 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Pair of pliers and yank and twist, there just spot welded on... All u lose is a child seat restraint
  4. Aug 12, 2011 at 12:31 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Drill out the spot welds, then take a hacksaw blade and saw in between the hook and wall. Don't use a hammer or you'll end up bending the crap out of the back wall.
  5. Aug 12, 2011 at 12:33 PM
    animal93
    animal93 Well-Known Member
    lupe
    weslaco texas
    2008 perunner
    just hit it with a hammer they come off easy.
  6. Aug 12, 2011 at 12:39 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    This ^
    You may want to check the legallity of it too.
  7. Aug 12, 2011 at 12:44 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    49 CFR Parts 571 and 596
    New vehicles are federally mandated and required to have them (from the manufactor), I don't know how this affects removal by an individual.
    Surely you will not get pulled over and asked for your restraints, but removing could affect resale and trade-in for you later.
  8. Aug 13, 2011 at 9:43 AM
    OldDog
    w.mass
    2010 reg cab 4X4
    Hey Guy's thanks for your help.
  9. Aug 13, 2011 at 9:02 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Honolulu, HI
    17 Inferno TRD-OR DCSB 4x4
    Bakflip Revolver X2, Hertz spkrs & JBL MS-8 DSP, PopnLock, HIDs, LEDs, & other minor mods
    I just drilled out the 3 spot weld points and they popped right off.
    These are only used for the center upper restraint and are not needed because you still have the two lower LATCH points in the seat cushions. Although it really depends on the type of car seat that your using, you really only need the lower two points for the majority of the seats out there. Honestly, I have never used the top center latch...only the two lower ones.
  10. Aug 15, 2011 at 9:12 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I took a Dremel and a cutting wheel and cut the weld between the hook and the backing plate, then knocked the hook off of the plate.
