Car Totaled Due to Frame Damage - 1999 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logzor, Jun 5, 2015.
  1. Jun 5, 2015 at 1:41 PM
    Logzor
    Logzor [OP] Well-Known Member
    I was rear-ended on my drive to work this morning. Now my rear bumper is bent down significantly. The frame is just a rusty mess like you wouldn't believe. So imagine for a moment trying to remove the bumper and bumper brackets and replace it with a new one.
    The wizards at St. Farm told me to take it to a body shop for estimates. I took it to two different ones, one was private and the other was in their Preferred Provider group. Both shops told me they would not or could not repair the damage. They wouldn't even write an estimate.
    Now St. Farm has me taking it in for an estimate by one of their staff. What can I expect and what should I be fighting for? Full blue-book value? Cost of a new bumper? New frame? A new 2016 Tacoma?
    Any help or advice would be greater appreciated.
  2. Jun 5, 2015 at 5:04 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    all the insurance will cover is accident damage and you can bet they will blame the rusty frame foe the extensive damage and tell you its only covering the bumper and bumper brackets.
    you need someone to defend your interests in this so keep looking for a trusted place to do a true estimate and give you good advice.
    also you need to check if your truck is covered in the frame rust warranty, you may be able to get the frame replaced and that is a huge factor as to what to do next.
  3. Jun 5, 2015 at 7:58 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    He wont be able to get it replaced in a 1999 Tacoma, those were bought back and scrapped if they had rusty frames. Only the 01-04 Tacomas got frame replacements.
  4. Jun 6, 2015 at 7:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Lets see some pictures of the damage??
    A rusted out frame is one thing accident damage quite another .
    Thing is if you don`t have the skills or have a friend to do the work the cost would be so expensive !!!
    Pictures !!!
  5. Jun 6, 2015 at 7:31 AM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    I would take it to Toyota and have them look at the frame because if it is covered under the frame warranty then Toyota will buy it back for 150% of bluebook from what I have been reading.
  6. Jun 6, 2015 at 5:56 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^ 99's are past their coverage life. 15 years after in service date. At this point I believe 01's are the oldest tacos that are still within their "in service date" IF they were inspected and depending when that date was even some of them may be already past coverage.
  7. Jun 6, 2015 at 11:03 PM
    2004TacomaSR5
    Jon
    Montana
    Yep, nothing can be done about the frames on the pre 01 Tacomas, the warranty is gone and you are screwed if your frame rusts on a 95-00 model.
  8. Jun 8, 2015 at 5:10 PM
    Logzor
    Yep I had the frame looked at last year and it barely passed. State Farm quoted me $1000 for the repair but the shop says there is a good chance they will damage the frame swapping out the bumper. I'm trying to get a clear answer from them what the payout is if that does happen. Will try to post a picture soon.
  9. Jun 8, 2015 at 5:38 PM
    keakar
    karl
    louisiana
    well you definitely want to buy it back for salvage value and selling the parts off it will bring you several thousand dollars for it. unless its completely trashed truck everything undamaged on it has good value here with other taco owners looking for those parts from seat belts to ash trays you would not believe hoe every part of it has good value. just saying to think hard before you let the scrap guy take it because he is going to keep it himself and sell all those parts
  10. Jun 8, 2015 at 7:09 PM
    Logzor
    Noted. The truck is in perfect working order. Would be a shame to scrap it or part it out. I could skip the repair, pocket the cash, and use a jack to bend the bumper back....
  11. Jun 8, 2015 at 7:17 PM
    keakar
    karl
    louisiana
    I wouldn't play with weak frames so have it boxed in and fully reinforced in the bad sections or better even to source a salvage yard frame from wrecked truck to swap out the rear frame sections with would be my suggestion on the permanent way to make it last you forever. many people do this to "save" their trucks
