Car Wash and Tonneau
Discussion in 'Detailing' started by civictotaco, Jan 15, 2011.
  1. Jan 15, 2011 at 12:50 PM
    civictotaco
    civictotaco [OP] Member
    2011 PreRunner SR5
    Just installed my tonneau cover and after looking at my truck I need a car wash.
    Has anyone every gone through an automatic carwash with their Access® tonneau cover? Do you go in with it rolled up or not? And have you had any problems?
  2. Jan 15, 2011 at 1:43 PM
    Skidmark Brown
    Skidmark Brown Member
    Northern VA
    2017 limited 4x4
    I have an Access Cover and run it through the carwash all the time. I have not seen any negative effects of doing this.
  3. Jan 15, 2011 at 3:06 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Same as above. Just wash it.
    It does help to put some 303 Aerospace on the cover every now and then to keep it clean and make it harder for dirt to stick to the cover.
  4. Jan 15, 2011 at 7:01 PM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 Tacoma
    3'' Pro Lift, 275 70 17 Tires Rear Suspension TSB Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover
    I keep it closed as well, it definitely helps with keeping cover a bit cleaner.
  5. Jan 15, 2011 at 7:05 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    I go through the touchless car wash every couple of weeks when we're getting snow/ice in order to wash all the sand and salt off. I leave my Access cover down and have had zero problems, even with the ZOMG 200mph blow dryer it uses.
  6. Jan 20, 2011 at 4:39 AM
    civictotaco
    2011 PreRunner SR5
    Thanks guys, I took the truck w/ the tonneau cover down through an automated car wash (not touch-less) yesterday it stayed secured even with the blower at the end.
