Car Wash Plus+ (New Meguiar's Product)
Discussion in 'Detailing' started by NMTrailRider, Jan 18, 2017.
  1. Jan 18, 2017 at 3:27 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    Check this out-- It's a new car wash soap that you apply directly to a wash mitt or sponge. No buckets required (but it's NOT a waterless/rinseless product). You use it much like you'd use a shower gel on yourself. Apparently it contains mild abrasives for light polishing.
    You spray the vehicle down, apply soap to mitt, wash a panel, then rinse the panel. Then rinse the mitt and repeat on the next panel.
    At first glance, what are your thoughts?
    Here's a video: https://m.youtube.com/watch?v=kGjJ5ySOXEc
    Here's a link to the product on autogeek:
    Mush Mouse likes this.
  2. Jan 18, 2017 at 3:28 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Sounds like a lot of work
  3. Jan 18, 2017 at 3:30 PM
    NMTrailRider
    New Mexico
    I think it's meant to save you some work. But I haven't quite figured this one out myself. I just wondered if, and why, this might appeal to some of you.
  4. Jan 18, 2017 at 3:35 PM
    IPNPULZ
    going to be fun!
    I'll stick with the 2 bucket system
  5. Jan 18, 2017 at 3:55 PM
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    NOT a good idea if you care about your paint job. I know, it's a truck, but some people care about that stuff.
    Without properly using a foam gun and allowing the foam to carry away the dirt that it lifts away from the surface, all you will be doing is grinding it into the clear coat.
    Check out this link for proper car washing instructions! I have done the same in the past when detailing cars when I had my business.
    ((This is just my opinion however, he is correct and his methods work!))
    https://www.ammonyc.com/detailing/basic-car-wash/
  6. Jan 18, 2017 at 4:00 PM
    Abragus
    Abragus Well-Known Member
    Adam
    Suffolk, VA
    I agree with the above, where is all the dirt and grime going after your first pass on your vehicle? Probably right in the mitt. Then you take that mitt and wipe down your whole truck, picking up more grit as you go. Wet sanding your paint, and not in the controlled way.
    NMTrailRider[OP] likes this.
  7. Jan 18, 2017 at 4:01 PM
    IPNPULZ
    going to be fun!
    Other than a foam gun thats my wash method I have tools for wheels only and body only....
    ace96 likes this.
  8. Jan 18, 2017 at 6:37 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I can see it now. Someone saying I don't need a bucket anymore....where did all these swirls come from??? :rolleyes:
  9. Jan 18, 2017 at 10:00 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I wouldn't use it on a heavily soiled car. The mitt would be collecting all that dirt and you'll end up grinding it back on your car. I'll stick to plenty of water and water pressure to do my cleaning. The less rubbing, the better.
  10. Jan 23, 2017 at 8:22 AM
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    I would not try this at all, I believe in a foam gun and the two bucket method and that is it.
  11. Jan 23, 2017 at 9:33 PM
    Inferno_OR
    Inferno_OR Well-Known Member
    Nate
    '16 TRD OR - Inferno DoubleCab
    stock....for now
    the two bucket or foam works like a charm. if it aint broke, dont fix it.
    ace96 likes this.
  12. Jan 24, 2017 at 2:19 AM
    killerken
    Philadelphia
    One other thing to remember about Meguiars products is if they are not in there professional line probably not a great idea to use on your car as the pros Probably will not use that product either
    ace96 likes this.
