Car won’t start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rise007, Oct 30, 2019.
  1. Oct 30, 2019 at 9:51 AM
    Rise007
    Rise007 [OP] Well-Known Member
    2012 white Tacoma 5 speed manual
    My gears work perfectly fine but I have to turn on my truck with the button “clutch cancel starter” this is really weird because yesterday I still could turn on my car by pressing on the clutch pedal what could be the reason..... fuse, relay or do I need the whole clutch?
  2. Oct 30, 2019 at 10:08 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    If you can start it just fine using the "clutch cancel start" but not by actually depressing the clutch (and the truck drives just fine once started) then look into the clutch switch behind your clutch pedal. See if it's damaged or if it might need replaced, should be an easy fix.
    Rise007[OP] and mynewtoy like this.
  3. Oct 30, 2019 at 11:38 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ your switch is bad,easy too replace
    Rise007[OP] likes this.
