Car won't start, then randomly starts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kokopuffs, Mar 30, 2016.
  1. Mar 30, 2016 at 9:00 AM
    Kokopuffs
    Kokopuffs [OP] Member
    Vadim
    2011 Magnetic Tacoma TRD off road
    So I have a 2011 Toyota tacoma, Magnetic Grey TRD off road. I got up this morning to go to school and my car won't start. I used my key to open the door, sat on the seat, no lights were on at all, put the key in, turned it, and nothing. I started clicking the warning signal lights and kept twisting the key. But nothing worked. So I said screw it, I'm late for class. I had to manually lock the door as I got out. As in warming up my motorcycle (10 yards from my truck), the warning lights start going off on my tacoma. I went back into the car, the passenger airbag light was on (like it always is) and the red key indicator was flashing. I put the key in the ignition and turned it. BOOM...it started. So I took the motorcycle to school this morning. What could be the problem?
  2. Mar 30, 2016 at 9:03 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What mods have you made to the truck?
    Aftermarket electronics installed?
  3. Mar 30, 2016 at 9:05 AM
    Kokopuffs
    Vadim
    All I have is HID's. Truck has 33k. Miles. I must also say that my click in the car is wrong. I correct it, the following day the time is way off.
  4. Mar 30, 2016 at 9:06 AM
    T4RFTMFW
    Check the battery connections.
    ridefreak likes this.
  5. Mar 30, 2016 at 9:09 AM
    Kokopuffs
    Vadim
    Just a side note. When the car wouldn't start, I had to use my hand to push the nob on the door to lock it. When the car started and I was exiting the vehicle, I used the electronic button to lock all the doors, and it worked.
  6. Mar 30, 2016 at 9:10 AM
    T4RFTMFW
  7. Mar 30, 2016 at 9:11 AM
    Kokopuffs
    Vadim
    I'll be home in 8 hours. I'll post back and let you guys know
  8. Mar 30, 2016 at 9:12 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Most likely battery if nothing was working. I had a 2011 and the battery failed within 2 years.
  9. Mar 30, 2016 at 9:13 AM
    T4RFTMFW
    Make sure they're tight and the terminals are clean.
    Pull them off, check both out, reinstall.
  10. Mar 30, 2016 at 2:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Battery connection or battery...
    shakerhood likes this.
  11. Mar 30, 2016 at 2:21 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I've had vehicles do the craziest shit and almost everytime it has been poor battery connections. Like everyone has said, inspect terminals, clean, clean, reinstall.
    Also, I'm still on my original battery. Kinda wondering when it'll die.
  12. Mar 30, 2016 at 2:29 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If it's not the battery or cables it may have something to do with the security keys. If you have another key, try using it for awhile.
  13. Mar 30, 2016 at 4:06 PM
    Kokopuffs
    Vadim
    Haha, my ground wire bolt was loose im so dumb. I was about to buy a new battery. Thank you guys! Greatly appreciate it!
  14. Aug 18, 2016 at 5:49 AM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    I'm going to revive this thread....
    I have had intermittant issues where my truck wont start. It happens in the morning after sitting all night. This morning was the second time, first time was this past Saturday. When I go to start it all of the lights on the dash light up like normal but it turns over slow for a second or tow and then nothing after that. Both times that this has happened I put my battery charger on it (set at 10 amp charge) and after a few minutes on the charger the truck starts up like normal. I had the battery checked at Advance Auto on Sunday and it checked out okay. After I had it checked I went home and cleaned the battery terminals and reinstalled them. I left the charger on the battery Sunday night (set at 2 amp charge) just to be sure I had a fully charged battery on Monday morning and everything has been good until this morning. The battery is 5 years old and while the truck is running my sacangauge is showing 13.4 volts +/- .3. I'm thinking about having the battery checked somewhere else. I will say that I had my frame replaced a month ago so I'm also thinking it might be a ground issue...maybe one has come loose.
    Anyone have any ideas?:notsure:
  15. Aug 18, 2016 at 6:09 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Sounds to me like you need a new battery. Once you hit 5 years, you're pretty much on borrowed time. Even if it turns out to be something else, your battery is at the end of its life, so you might as well replace it. Definitely where I'd start, as your symptoms seem to me to point to the battery anyway.
  16. Aug 18, 2016 at 6:11 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Check battery connections - clean posts and cables.
    Mine shows 13.4 on a volt meter after it's fully warmed up. Cold - it should be above 14.00. Seems like all of my Toyota's read 13.4 once warmed up.
    I too would be suspicious of grounds, especially after the frame work. Would not hurt to check connections on the alternator as well + get a voltage reading on the alternator. Should read 14.0 or slightly higher measuring at the B+ terminal with the red lead and black lead on alt. case(ground).
    Last, but not least, the battery is 5 yrs. old. I'd say you did well. It's my opinion that today's batteries don't last as long. Too many current-robbing gadgets inside modern vehicles, but I would not replace the battery until you checked out everything else first.
  17. Aug 18, 2016 at 6:21 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    13.4V when running means the alternator is probably not the problem, but doesn't indicate the health of the battery.
    Check for parasitic current draw with a multimeter set to measure battery current while the truck is shut off.
    If parasitic current draw is not excessive, replace the battery.
  18. Aug 18, 2016 at 6:25 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    I'd be very surprised if this turns out to be anything more than a failing battery.
  19. Aug 18, 2016 at 6:30 AM
    Nate-O
    Nate
    PreRunner
    Thanks for everyone's suggestions. I'm going to try and have the battery checked somewhere else on my lunch break.
    A failing battery would be the easiest and least time consuming fix. With 3 kiddos at home spare time is a rare commidity.
  20. Aug 18, 2016 at 10:09 AM
    Nate-O
    Nate
    PreRunner
    I had the battery checked at O'Reilly's and they said the battery was bad and the voltage regulator failed when they checked it while the truck was running. Then I thought what the hell, Autozone was a few blocks down the street so I had them check it too. Same thing at Autozone as far as the battery being bad but when they checked the voltage regulator, first time it failed, second time it passed.
    With the battery being 5 years old I think I'm just going to get a new one and hopefully the alternator is okay.:fingerscrossed:
