Car won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Oct 30, 2017.
  1. Oct 30, 2017 at 4:37 AM
    donlogan
    donlogan [OP] Well-Known Member
    Drop off my dog at daycare. Get in my 95 2.4L manual transmission and she won't crank. Nothing. Lights won't come on. Seems like dead battery. Going to get a jump.
    One odd I did notice is that my after market radio flickers on and off sometimes.
    Just thought I'd post this while I wait for my jump.
  2. Oct 30, 2017 at 4:39 AM
    donlogan
    Just noticed that when I turn the light switch in I hear a faint clicking sound.
  3. Oct 30, 2017 at 4:41 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Sounds like its just a dead battery man. Low voltage causes electronics to do crazy things.
    wilcam47 and donlogan[OP] like this.
  4. Oct 30, 2017 at 4:44 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Same thing happened to me in my 06 last week. 2nd battery, 7 years old, no prior symptoms, just dead. In the past I’ve always had at least a few weeks starts as a warning.
    donlogan[QUOTED][OP] likes this.
  5. Oct 30, 2017 at 6:36 AM
    donlogan
    So I tried to jump start it ... it's cranking now but not enough to start. I gave it two or so minutes to charge up without any luck. Do I need to wait longer for it to pop? Or is it possible that the battery is too far dead for a jump to work?
    I don't want to buy a new battery if it's still not going to start.
    Please advise great TW forum
  6. Oct 30, 2017 at 6:39 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    If the jumper car is running it should start it right away. Maybe let it charge for 5 minutes with the other car's RPM's a little higher?
    wilcam47 likes this.
  7. Oct 30, 2017 at 6:40 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    A multimeter would be your best bet to check
  8. Oct 30, 2017 at 7:16 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Try this: disconnect, clean, replace the battery terminals.
    With corroded connections, sometimes even tapping on the terminals
    will create a better connection, just to get you home.
  9. Oct 30, 2017 at 7:49 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Very much this. It's a good idea. If it doesn't work, take the battery to your local autozone/oreilly's/walmart/whatever and have them charge up and test your battery.
    Also, if your stereo is flickering, you may have some bad wiring somewhere. Cleaning your terminals is a good start, but who installed your stereo, and how recently? Solder/crimp/electrical tape? If you have some sort of intermittent short/parasitic drain, that could have killed your battery.
  10. Oct 30, 2017 at 7:51 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    alternator
    aside from now needing a new battery....
  11. Oct 30, 2017 at 8:02 AM
    cgrhyne
    cgrhyne Well-Known Member
    Cameron
    Lincolnton, NC
    2002 4Runner (the best 3rd gen)
    Bilstein/OME Lift, 5th Gen Wheels, BFGs, fun stuff... Had a 3rd Gen, twin turbo'ed it (traded in on a F150 Gen 2 3.5 Ecoboost)
    My 02' 4Runner does this from time to time. Best I can figure its a light relay. If I leave the lights on and cut the truck off, every now and then it keeps trying to close and kills the battery. To get it to reset, you have to remove the negative lead, let it sit for a few minutes, then reattach it. Seems to fix it for me. I keep a jump box in the back and jump it off when it dies (have had to do this maybe 3 times in the 18 months I've owned it).
  12. Oct 30, 2017 at 8:55 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I've jumped cars with extremely dead batteries by disconnecting the dead battery entirely and hooking the jumper cables to the battery cable ends. But, this is a manual transmission truck, right? Roll start it.
  13. Oct 30, 2017 at 9:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sometimes the battery is so dead it needs a few minutes to charge. likely its a bad alternator (but not always the alternator) that in turn used up all the battery. hope you get it going, could be just a bad battery.
  14. Oct 30, 2017 at 9:03 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    When my battery finally died it just died hard. I left the office to drive to a meeting 22 miles away. It started just fine but when I came out of the meeting it didn't have ANY power. I got a jump and got home. Before turning it off I put the meter on it. 14.1 volts so the alternator was trying to charge. Turned it off and there was 10 volts between terminals. The battery was toast. It happens.
    donlogan[OP] and wilcam47 like this.
  15. Oct 30, 2017 at 9:08 AM
    donlogan
    I ended up getting a jump from a tow truck. I guess it had more juice than my friend's car.
    If it was the alternator, wouldn't the truck die immediately after starting it? I was able to drive it home 20 miles after the jump start so I'm guessing the alternator is good.
    wilcam47[QUOTED] likes this.
  16. Oct 30, 2017 at 9:12 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    How old is the battery? I have had some that last 7 years, and others that make it 2 or 3. Some show signs like hard to crank with a/c on, and others that I have been driving, stop by a 7-11, come back, and wont turn over with no warning signs.
  17. Oct 30, 2017 at 9:15 AM
    wilcam47
    Will
    Bourbon state
    not necessarily depends how long the tow truck charged it but being you just had enough to jump start I'd think battery first. If the alternator is working properly it has enough voltage to keep it self running. If it was bad it wouldnt have enough voltage to keep itself running and used the battery till its depleted.
  18. Oct 30, 2017 at 9:30 AM
    donlogan
    4 years old. AutoCraft brand.
    I didn't get any hard cranks. There have been a handful of times over the past three months where when I went to start I would only hear a clicking sound. It usually started on the second try. I didn't think twice about this because prior to replacing my clutch master and slave cylinders I had the same issue, without the clicking sound though. I became desensitized to the starting issue.
    If there's one thing I'm learning by having an older vehicle it's that you can't ignore symptoms. Like everything has a cause and it's best to figure that out before your stuck at an inconvenient time and place.
    Like now all I'm thinking to myself is why the fuck didn't I do a double take when I experience a non-start and clicking noise on several prior occasions...like wtf was I thinking....hello....get that check out.
    Anyway, lesson learned. Lots of lessons learned on my Tacoma.
  19. Oct 30, 2017 at 4:49 PM
    donlogan
    New battery in....everything is so bright now!
    Just the other day I was thinking to myself as I drove 'damn these headlights are weak as hell'. I totally ignored a bunch of low battery signals.
  20. Oct 30, 2017 at 6:46 PM
    wilcam47
    Will
    Bourbon state
    Great!
