Carb help!!
Discussion in 'All Terrain Vehicles' started by jab08, Sep 22, 2011.
  1. Sep 22, 2011 at 10:49 AM
    jab08
    jab08 [OP] Well-Known Member
    Alabama
    02 T4R 4wd
    I need some help!! I have a 2002 yamaha big bear 400. It has a mikuni carb on it. Its been sitting for about a year and I'm trying to get it running. Iv cleaned out the jets and the bowl. What I'm running into is that it will not run but if you put you hand over the intake it will start right up and idle. I'm not sure what the problem is? Tuning or does the carb need rebuilding?? Thanks for the help and sorry if it don't make sense I'm typing on my phone.
  2. Sep 22, 2011 at 12:31 PM
    jab08
    Alabama
    02 T4R 4wd
    Any clues??
  3. Sep 22, 2011 at 12:36 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    From my experience when the float needle (I can't remember what it's called exactly right now) under the floats is gummed up the motor will start and run with full choke on. I'd pull it apart and clean out all the jets also. Try to avoid moving the air screw though, or turn it in and count how far it was backed out before anything else.
    edit: just read you've cleaned all the jets, I'd look at the float seats again.
  4. Sep 22, 2011 at 12:46 PM
    jab08
    Alabama
    02 T4R 4wd
    Ok thanks man! I just took it completely off so I can clean it real good. Hope it fixes it.
  5. Sep 22, 2011 at 8:13 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Any luck with that? I'm hoping after you get it back together it should run just fine.
  6. Sep 25, 2011 at 2:49 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    Are you blowing everything out with an air compressor after you clean it? If there is any small amount of trash in there it will cause problems. Ask me how I know. :)
  7. Sep 25, 2011 at 3:11 PM
    jab08
    Alabama
    02 T4R 4wd
    Thanks everyone!! But I took it apart and let it soak in some cleaner, just haven't had time to put it back together. But good tip on using an air comp. Before I put it all back together. I'll keep you all updated.
  8. Sep 25, 2011 at 3:14 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ive rebuilt so many carbs and that float and the pin needs to be perfectly free of varnish and gum to get it to run without the choke. what I usually do is get a big can fill it with paint thinner and then let the entire carb soak and then take a tooth brush pick or whatever and work on it until everything is smooth. When you stop riding it again make sure to empty the carb and put fuel stabilizer in the bike or empty the tank.
  9. Sep 25, 2011 at 3:20 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    1. The needle that is connected to the float and the carb on the pivot end is stuck closed.
    2. The air fuel mixture is not right. Could be due to the screw missing or out of adjustment. Having the screw out would make it to rich or if it's tofar in then to lean. The screw is on the bottom of the carb and as for a yamah keihn It carb should be a very small flat head to adjust. Screw it all the way in then out 2 full turns. See if it runs. If not proceed to a turn a half turn again and check.
    3. Could also be improper jetting. Has there been any motor work, intake work, exhaust or anything done to it. If so it may need to be rejetted. Does it have an air box lid?
  10. Sep 25, 2011 at 3:39 PM
    jab08
    Alabama
    02 T4R 4wd
    Thats exactly what I was about to ask about how many turns on the screw. I counted but just was wondering. But its completely stock.
  11. Sep 25, 2011 at 5:00 PM
    YFZ450MOE
    Moe
    If it's completely stock clean your filter and put the air lid box back on. Turn the screw in all the way but just snug. To tight it will snap off. Then go out 2 turns. See how she runs, if it's like shot then go out a quarter to a half more. Then repeat till you get what you want and it sounds good. Run it through the entire RPM range and when ya get it close there won't be any pop on the deceleration of the engine. Let me know what ya get!
  12. Sep 25, 2011 at 5:52 PM
    jab08
    Alabama
    02 T4R 4wd
    Ok thanks!! I hope to get it running in the next few days.
  13. Sep 27, 2011 at 9:23 AM
    jab08
    Alabama
    02 T4R 4wd
    Ok I think Im getting close!! My friend put it back together for me and said it runs fine but its popping through the intake during deceleration. Does that mean that its running to rich or to lean??
  14. Sep 27, 2011 at 9:29 AM
    jab08
    Alabama
    02 T4R 4wd
    Thanks!! I just picked up 2 new plugs just in case I foul them out before I get the correct tune. How much should I look at turning the screw to rich it up? 1/8 to a 1/4 turn maybe?
  15. Sep 27, 2011 at 12:11 PM
    jab08
    Alabama
    02 T4R 4wd
    Ok well it will not idle for very long without popping then cutting off. I put in a new plug and keep letting out a 1/4 turn wich should rich it up correct? However I keep checking the plug and the tip is getting white which means its still running lean correct? Should I keep adjusting the screw or what should I do?
  16. Sep 27, 2011 at 12:55 PM
    jab08
    Alabama
    02 T4R 4wd
    I think it only has a idle gas screw. At least I think. That and the high and low speed jets is all that I see on the carb.
  17. Sep 27, 2011 at 1:32 PM
    jab08
    Alabama
    02 T4R 4wd
    Yes very true lol!! How would I determin which one it is?
  18. Sep 27, 2011 at 4:35 PM
    YFZ450MOE
    Moe
    Popping on the decel is to lean. so yes, correct. Keep turning out the screw a 1/4 turn at a time, if you get to the end of the screw when its to loose and won't stay where it should then, go up one on the pilot jet. Then start it all over again, screw all the way in, then out 2, then a 1'4 turn at a time. Having your plug look like a brown paper sac is what your aiming for!
  19. Sep 27, 2011 at 5:07 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Your quad has a fuel screw and idle adjuster. 2.5 to 3 full turns out on the fuel screw for those yamahas is ideal. Did you make sure the jets were completely clean? Could you see daylight through them? When you re-installed fuel screw, was there a spring, a washer and a tiny o-ring? You also need to blow air through the carb where the jets screw in to make sure all the internal passages are completely clear. If you have anymore problems PM me, I do this for a living.
  20. Sep 27, 2011 at 7:35 PM
    jab08
    Alabama
    02 T4R 4wd
    It is running way too lean and Iv about got the screw all the way out. YFZ450MO when you say go up one on the pilot jet what exactly do you mean? 1 turn in or out? And WTtoolman all the jets are spotless I have cleaned them like 4 times already and yes the fuel screw had a spring and a washer cant clearly remember if it had a o-ring though.
