Carbon Build Up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BobcatSR, May 11, 2021.
  1. May 11, 2021 at 2:53 PM
    BobcatSR
    BobcatSR [OP] Well-Known Member
    2021 Trail Edition AG 2017 DCSB SR (Sold)
    4" Maxtrac Spindles 17x9 Bronze Fuel Blocks 285/70r17 Toyo Open Country at3 MBRP Dual Exhaust ME-S0 Climate Control Rings Pool Ball Shifter & TRD Boot Collar Cap Demon Hooks Viofo A119 V3 with Dongar RockyMounts LoBall
    I noticed this the other day and it seems a bit excessive for a truck with 2k miles on it. Am I putting too much load on this truck or is this normal for atkinson cycle engines? I generally stay under payload with the occasional load that is a bit more but only for going around the corner. Cosmetically I couldn't care less, but I am curious if this truck is running abnormally rich or something. The only threads I could find on this were about carbon residue on the rear bedside and not so much related to this concentrated of a build up. This is not my first truck by any means but I've never noticed this before on any of my previous trucks.
  2. May 11, 2021 at 3:04 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  3. May 11, 2021 at 3:05 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Interesting - is that actually carbon? Do you have access to a scan tool which can show your fuel trims? That reminds me of a carburetted engine that's running way too rich.
    BobcatSR[OP] likes this.
  4. May 11, 2021 at 3:11 PM
    BobcatSR
    I assume so? My understanding is that direct injection engines are known for carbon build up, and these atkinson engines are part direct injection or something. I do not have access to such a scan tool but now I'm wondering about getting my hands on one.
  5. May 11, 2021 at 3:13 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Interesting.
    I had no black soot on the stock tune. Now tuned, I get a little bit at the bottom of the exhaust tip.
    Your engine is still breaking in so maybe that’s why:notsure:
    FWIW, I had 165k miles on my 4.0 ranger and the exhaust pipe was super clean inside.
    Tacosha and BobcatSR[QUOTED][OP] like this.
  6. May 11, 2021 at 3:17 PM
    tirediron
    That refers to carbon build-up in the heads, valve face, etc. This appears to be excess fuel and while I don't think it's likely to a huge concern, I would get it looked at. As your brand-new, take it to the dealer and ask them to check it out.
  7. May 11, 2021 at 3:17 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Did you go up any extra steep inclines? I've heard the 3.5 has oil burning issues when climbing steep hills.
  8. May 11, 2021 at 3:19 PM
    BobcatSR
    Hm. Could be! I'm guessing that probably is the case, it just seems odd. I also had a ranger with a 4.0! Bought it around 140k and the odometer turned over 180k when the buyer was taking it on a test drive, and the exhaust pipe on that truck was also clean. :notsure:
    Junkhead[QUOTED] likes this.
  9. May 11, 2021 at 3:20 PM
    BobcatSR
    I remember hearing about that! Good suggestion but I have not!
    MalinoisDad[QUOTED] likes this.
  10. May 11, 2021 at 3:22 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Truck idle a lot? Location?
    MalinoisDad likes this.
  11. May 11, 2021 at 3:27 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    From what I saw and keep on noticing, all rangers with 4.0, 3.0 and 2.3 all had
    super clean tailpipes. I even had K&N 63 series and welded in magnaflow muffler.
    At the time when I had my ranger, my buddy had a 13 trd sport and the exhaust pipe turned pitch black on the inside almost instantly. I did hear that the 2GR FE ran a bit rich though.
    BobcatSR[QUOTED][OP] likes this.
  12. May 11, 2021 at 3:28 PM
    BobcatSR
    Decent amount of city driving (Atlanta) so I suppose that would mean it does its fair share of idling, but its mostly just low speed stopping and starting. I did just drive to Mississippi and back, and I did some poking around and saw some article saying that direct injection engines may produce more build up if running at high speeds for long intervals. But, this definitely caught my eye before that trip.
  13. May 11, 2021 at 3:34 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Let it break-in, do an oil change, check again, IMO.
  14. May 11, 2021 at 6:26 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    That's water mixing with some soot in the exhaust. Your trucks fine.
    turbosnail, willtill and shakerhood like this.
  15. May 11, 2021 at 6:45 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    the angle of the exhaust looks like it's angling up slightly. This allows water mixed with soot to wick instead of drip
  16. May 11, 2021 at 6:47 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    I don’t have that. I want to chop that shit because I get carbon dust on my rear fender. But none coating the tip like that.
  17. May 11, 2021 at 7:45 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is it soot? Looks pretty crusty...like burnt on tar.
  18. May 12, 2021 at 5:00 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Too many short trips.
    willtill likes this.
  19. May 12, 2021 at 5:15 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Funny you should post a picture like that. If i run premium gasoline in my 3.5 v6 the tail pipe looks exactly like that. Switching back to 87 octane fuel....after a couple tanks the tail pipe end turns to a nice tanish/gray color. All that sooty black is gone.
  20. May 12, 2023 at 2:30 AM
    Xbowguy
    Xbowguy Well-Known Member
    Jeff
    Pa
    2023 Tacoma 4x4 SR5 double Cab Barcelona Red
    I seen on a YouTube vid about likes dislikes of the 2023 Tacoma V6. The dude say periodically it go in diesel model to recirculate gas emissions to clean out carbon buildup
    see link
    https://youtu.be/eqJe5OCdjZc
