Carbon fiber bezel/bowl
Discussion in 'Lighting' started by boltstaco, May 15, 2013.
  1. May 15, 2013 at 2:01 PM
    boltstaco
    boltstaco [OP] Well-Known Member
    eric
    oceanside, ca
    panty droppa
    AFE intake, 3" spacer w blocks in rear
    Im about to start my fxr retrofit in a few days and thinking of wrapping the bezel and or bowl in 3m carbon fiber wrap. Has anyone done this mod? How hard is it? Reflector bowl shouldnt be too hard but the bezel has some crazy angles, tight spots to get to.
  2. May 15, 2013 at 2:21 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    The bowl wouldnt be hard but that bezel would take some patience and heat gun.
  3. May 15, 2013 at 2:31 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    havent done it, but this will be interesting to see...
  4. May 15, 2013 at 2:34 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    it would probably be easier to find someone to hydro-dip it for you
  5. May 15, 2013 at 2:41 PM
    Aw9d
    Aw9d That one guy
    I would hyrdro dip as the lines and angles are going to be rough to get it just right. But LOVE this idea.
  6. May 16, 2013 at 9:49 AM
    boltstaco
    eric
    oceanside, ca
    panty droppa
    Yea looks like ill go hydro dip method. Will post pics when done
  7. May 16, 2013 at 9:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd leave the bowl chrome and dip the bezel and shroud. Just my $0.02. Can't wait to see this regardless of what you do :popcorn:
  8. May 17, 2013 at 6:25 AM
    MIAtaco
    Brian
    Miami FL
    if you dip it make sure its perfectly smooth so the pattern will come out right
