Carbon fiber drive shaft
Discussion in 'Performance and Tuning' started by skyking3, Feb 17, 2017.
  1. Feb 17, 2017 at 6:32 PM
    skyking3
    skyking3 [OP] Well-Known Member
    Tom
    2025 Tacoma TRD Sport Hybrid
    TTD billet oil cap ---All following mods were for my 3rd gen --TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    After doing a search there are several people who have talked about a adding a carbon fiber drive shaft but no one has ever installed one, at least that I can find. There are a couple of places that advertise carbon fiber drive shafts for under $1000. It seems that the low end torque should be improved which this 3rd gen truck really needs. This makes a lot more sense than carbon fiber wheels which are going for $12k-@16k a set. Anyone have any experience with this.
    Bray1197 and ChadsPride like this.
  2. Feb 17, 2017 at 6:33 PM
    ChadsPride
    Sponsored by TacomaWorld.com
  3. Feb 17, 2017 at 6:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    So..... changing from a steel to carbon fiber drive shaft improves torque? How? Less mass to rotate?
    I'd stick with HP stickers.
  4. Feb 17, 2017 at 6:41 PM
    skyking3
    Tom
    ChadsPride likes this.
  5. Feb 17, 2017 at 7:03 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    This has been a mod for drag racers for some time now. Any time you get rid of rotational mass you will gain power. Now, is 5-6 hp/lbs of tq that costs $1000 worth it? I guess it depends on the person.
    I do believe that the Tacoma's ds is aluminum though so the gain would be minimal.
    ChadsPride and Kyitty[QUOTED] like this.
  6. Feb 17, 2017 at 7:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    2nd gen's are steel. Mine is aluminum and significantly lighter even.
    Lord Helmet and ChadsPride like this.
  7. Feb 17, 2017 at 7:30 PM
    skyking3
    Tom
    Do you have any idea how much HP and torque you gained with your aluminum drive shaft? How much weight did you save?
  8. Feb 17, 2017 at 7:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sound like a pretty big sacrifice in durability for a truck that is advertised as off road worthy/ready. Can't imagine the 5-8HP is worth sacrificing impact resistance.
    TTT and ChadsPride like this.
  9. Feb 17, 2017 at 7:40 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Gotta get me some of that!
  10. Feb 17, 2017 at 7:59 PM
    skyking3
    Tom
    The aluminum crankshaft pulley that saves 3-4 pounds of weight on the crank produces 10-14HP so a carbon fiber drive shaft that saves around 20 pounds will produce more than twice as much HP gain.
    lilgerber and ChadsPride like this.
  11. Feb 17, 2017 at 8:02 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Whatever it cost would pay for itself in short order. Need group buy. Now
  12. Feb 17, 2017 at 8:24 PM
    Speedytech7
    I'm not buying that
    WOODEX M.E., Torspd and ChadsPride like this.
  13. Feb 17, 2017 at 8:29 PM
    skyking3
    Tom
  14. Feb 17, 2017 at 8:41 PM
    Bray1197
    Bray1197 Well-Known Member
    Bobby
    Myrtle Beach, SC
    2017 Tacoma Trd Pro
    A lot of stuff, just ask and I'd be happy to tell you. Or we could wheeling/camping
    Hmmmmm, I'm interested in this. What's the chance of it getting damaged off-roading?
  15. Feb 17, 2017 at 8:49 PM
    skyking3
    Tom
    Probably pretty good chance of damage if you go off roading. I use my truck for towing once a year and hauling several times a year, but never go off roading.
    ChadsPride, Speedytech7 and Bray1197 like this.
  16. Feb 18, 2017 at 7:01 AM
    Bray1197
    Bobby
    Myrtle Beach, SC
    2017 Tacoma Trd Pro
    U have a link to anyone of these places?
  17. Feb 18, 2017 at 7:15 AM
    skyking3
    Tom
    There are several places but I will probably go with this one since it is not far from where I live in Florida. They start at $659 and $125 for an aluminum yoke upgrade which I would go with since it saves another 3.5 pounds.
    http://www.pstds.com/product-category/all-carbon-fiber/
    You may want to consider aluminum at the same web site. You will still save weight and be able to go off road while paying half the price.
    Bray1197 likes this.
  18. Feb 18, 2017 at 7:24 AM
    Bray1197
    Bobby
    Myrtle Beach, SC
    2017 Tacoma Trd Pro
  19. Feb 18, 2017 at 3:48 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I can see what you are trying to describe, but thats not how that works at all in real life. those two items are located at completely different positions on the vehicle. Mechanical advantage/disadvantage and drivetrain losses come into effect on the driveshaft. Its also not a linear scale at all. You are only gaining back HP at your engine already has by creating less losses, but if 3 punds for a crankshaft pulley gains you back 7hp on the crank another 3 lbs will not gain another 7hp. Its diminishing returns. And therefore assuming youll be able to scale any estimated drivetrain loss savings is just pure speculation.
    Torspd likes this.
