Carbon Filter Delete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blueburban6, Jan 17, 2012.
  1. Jan 17, 2012 at 7:03 AM
    blueburban6
    blueburban6 [OP] Well-Known Member
    Nick
    Northern New Jersey
    2011 SR5 Double Cab 4x4
    Hello all. I've seen a few comments about a "carbon filter delete". I was wondering where it is? how its done? and is it worth it? I know it would be illegal because I assume you are messing with emissions but I am still curious.
  2. Jan 17, 2012 at 7:31 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Open up your intake like you're replace your air filter. You'll see it in there on the driver side of the air cleaner assembly. Black looking filter.
  3. Jan 17, 2012 at 7:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Removing it makes no difference on the V6 Tacoma. I regret taking mine out.
  4. Jan 17, 2012 at 7:41 AM
    blueburban6
    Nick
    Northern New Jersey
    What did it do when you took it out to make you regret it
  5. Jan 17, 2012 at 7:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It did absolutly nothing. It has no impact on the engine performance/ By removing it, I eliminated a device that could potentially stop some debris if the main filter failed for some reson.
  6. Jan 17, 2012 at 7:56 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    When he talks you better listen, we all set our clocks by him. If not, he gets more outraged than Stalin after a bad mustache trim.
  7. Jan 17, 2012 at 7:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt see the guy in the street...it was an accident....
  8. Jan 17, 2012 at 7:59 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Does the carbon filter need replacing or cleaning?
  9. Jan 17, 2012 at 8:00 AM
    blueburban6
    Nick
    Northern New Jersey
    I will be sure to listen then. lol. Thanks for the info.
  10. Jan 17, 2012 at 8:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    nope
  11. Jan 17, 2012 at 8:09 AM
    GP3
    California
    4X4 TRD Off Road
    Interesting. Thanks.
  12. Jan 17, 2012 at 8:13 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
