card reader
Discussion in 'Technology' started by coffeesnob, Jan 29, 2012.
  1. Jan 29, 2012 at 2:33 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Where on my dell laptop windoz 7 can I find out what type of sd cards it will read? :eek:
  2. Jan 29, 2012 at 4:08 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
  3. Jan 29, 2012 at 7:50 PM
    myname150
    myname150 Well-Known Member
    Windows 7* supports most (if not all) SD/SDHC cards as well as most card readers out-of-the-box. If your laptop already has a SD card slot then there is no need to buy another reader. Just stick the card in.
    A cheap USB card reader from walmart will work just fine if you don't already have a card reader.
    The dynex ones from Best Buy aren't bad either
    I shortened the URL. The Best Buy URL was ridiculously long. http://goo.gl/bzHCI
  4. Jan 30, 2012 at 3:04 PM
    coffeesnob
    VA
    I was wondering about being able to read the new hd cards sdxc.
  5. Jan 30, 2012 at 4:22 PM
    myname150
    If your laptop is recent I can't see why not. Do you know the exact model name for your Dell? Probably Inspiron something....
  6. Feb 4, 2012 at 11:32 AM
    coffeesnob
    VA
    yes it is an inspiron 1545
  7. Feb 4, 2012 at 9:27 PM
    myname150
    I think it would work. Give it a shot.
  8. Feb 5, 2012 at 5:51 AM
    coffeesnob
    VA
    ok thanks, I am buying a new camera that uses the new hd cards and would ust be dissapointed if I can't load it into my laptop...:)
  9. Feb 5, 2012 at 8:52 AM
    myname150
    Well if all else fails, most cameras have a mini/micro USB port and you can always use that route to transfer files over to your PC. I just do that with my blackberry if I'm too lazy to find my microSD to SD adapter :p
