Careful ,Changing oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kolohe07, Jul 21, 2024.
  1. Jul 22, 2024 at 11:27 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I'm not a copper, however I have 2 teenaged BS'ers. I just don't see how the this is possible. Perhaps OP used a $hitty impact?
    Rusty66 and soundman98 like this.
  2. Jul 22, 2024 at 11:58 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    You can see the o-ring from where I removed the plug and inserted the drain valve in the second pic.
    I like the function of the drain valve in that it pre-drains excess oil preventing a messy removal of the cannister.
    I have the TRD Skid and learned after the first time that the oil will splash and leave spots that need to be wiped down.
    The plug has never been over-torqued but the cannister has when oil changes were done at the dealership (during the 2yr maintenance plan).
    Now that I do my own oil changes, everything runs smoothly.
    I also installed Fumoto! :)
    Kolohe07[QUOTED][OP] likes this.
  3. Jul 22, 2024 at 12:47 PM
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    GilbertOz and BabyBilly[QUOTED] like this.
  4. Jul 22, 2024 at 1:33 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Something is not adding up. maybe you had the impact on tighten, not loosen, or you have a poor quality, low torque impact wrench? Every once in a while, the drain cap will be tight enough to remove the housing instead of the drain cap. When that happens, I retorque the housing, and break out the Milwaukee 3/8 impact, spins the drain right out. Not sure what is going on in your case. Ski
  5. Jul 22, 2024 at 2:28 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
  6. Jul 22, 2024 at 3:08 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    How long you been running this?
  7. Jul 22, 2024 at 6:01 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    I've been dealing with these on my Toyota's since 2012, through hundreds of thousands of miles and countless oil changes.
    Sometimes done by the dealer, sometimes Walmart, sometimes Quick lube and sometimes me.
    Never had any of the problems that seem to trickle down the 3rd gen forum feed on TW.
    If lefty loosey, righty tighty isn't working, maybe TW needs to collectively hit the gym, IDK.. ¯\_(ツ)_/¯
    soundman98 likes this.
  8. Jul 22, 2024 at 6:11 PM
    Kolohe07
    Kolohe07 [OP] Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    Impact drill hit with enough force to break off one of the fins.
    I quit after that not wanting to damage the canister any more.
    Git over it
  9. Jul 22, 2024 at 6:24 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i dunno, i still suspect that it was over-torqued last time.
    skidooboy likes this.
  10. Jul 22, 2024 at 6:34 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    After my last round of oil changes in the garage, I’ve realized that taking the extra 5-10 minutes of loosening the oil drain bolt and filter housing then letting the oil run out slowly is much less frustrating than dealing with the sudden volume of oil gushing out, then the cleanup.
    02Duck likes this.
  11. Jul 22, 2024 at 7:06 PM
    AustinNative
    ATX
    Almost 2 years now.
  12. Jul 22, 2024 at 7:27 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I just loosen it enough to where the oil starts seeping out and let it drain in a big bucket. when it stops i then unscrew it and dump the remaining oil that's in the cap in the bucket. messy, yea, but mostly oil on my hands.
    i have the skid plate off. i guess some models have a hole in the skid plate and do not have to remove it. in that case, yea, big mess.
    Kolohe07[OP] likes this.
  13. Jul 23, 2024 at 7:25 AM
    skidooboy
    central lower mich
    Then you are doing it wrong. leave the cannister housing on the truck, insert 3/8 extension attached to impact wrench into drain cap square hole, pull trigger, drain cap will spin loose no drama, unless it was waaaay over torqued to begin with. I fail to see how you broke fins off the cannister, using the method, described above. No fins are contacted by anything. the worse you could do it, spin the housing off. Something is not adding up. Ski
  14. Jul 23, 2024 at 7:41 AM
    jmneill
    SE
    He used the impact with the housing tool after failing in his attempt to remove the plug.
    Double fail, apparently..
  15. Jul 23, 2024 at 8:49 AM
    #35
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    My guess is u might have cross threaded the bolt when putting it back in from your other oil change .
    kahanabob likes this.
  16. Jul 23, 2024 at 9:07 AM
    #36
    Kolohe07
    David
    Haiku , Maui, Hi
    No I used a pipe wrench to hold the canister still after I removed it.
    Impact drill was used on the plug
  17. Jul 23, 2024 at 9:08 AM
    #37
    Kolohe07
    David
    Haiku , Maui, Hi
    No, it was hand tightened before tourqed
    pretty sure it would have leaked if it was cross threaded,
  18. Jul 23, 2024 at 9:11 AM
    #38
    Mallcrawler20
    Even if u hand tighten it can happen .
  19. Jul 23, 2024 at 9:11 AM
    #39
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Removing the cap or not, I have NEVER gotten out without a mess on this thing. So I just make life easier and don't.
  20. Jul 23, 2024 at 9:24 AM
    #40
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    This is how clean the cannister/filter looked after pre-draining--much less of a mess.
    And of course, the aluminum housing that replaced the plastic.
