Careful ,Changing oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kolohe07, Jul 21, 2024.
  1. Jul 23, 2024 at 9:27 AM
    #41
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Something's not right when you need a pipe wrench or an impact for an oil change, let alone both..
    soundman98 and kahanabob like this.
  2. Jul 23, 2024 at 9:29 AM
    #42
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    If I am going to spew/drop oil and need the pan to catch it all, I don't care if it's a couple drops or a gallon. It's going to dump into the pan I have to have under it anyway. So, why both if I have to move the catch can under it and unscrew it anyway, and get dirty no matter what...
    Just extra steps, it's gonna suck either way.
  3. Jul 23, 2024 at 9:32 AM
    #43
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Would you like to know about the slide hammer used for fuel injectors? :p
  4. Jul 23, 2024 at 9:32 AM
    #44
    jmneill
    SE
  5. Jul 23, 2024 at 9:37 AM
    #45
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The filter cap drain plug was also stupid tight on mine from the factory. I've just been removing the cap directly without draining it first. Doing the same with my 4Runner too, as it has a similar filter cap.
  6. Jul 23, 2024 at 9:41 AM
    #46
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I use the Auto Hobby Shop on Dover AFB; $8/hour for stall use.
    I'm usually done in 30 minutes but know I have an hour to complete the job.
  7. Jul 23, 2024 at 9:48 AM
    #47
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Mine was so tight the entire canister turned,, i just removed the entire canister and have never used the drain plug.
  8. Jul 23, 2024 at 10:02 AM
    #48
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    That actually happened to me as well on the very first change (no dealer for me). Was very surprised when the whole thing started turning. I was still able to take it off with the cannister out. No issues since then.
  9. Jul 23, 2024 at 10:35 AM
    #49
    Sasquatchian
    Sasquatchian Well-Known Member
    It's been documented on other threads here on TW that the oil canister, even when properly torqued when your oil is changed, does tighten itself up over time. From memory, the reasons given had to do with heat cycling and it's a real thing, so it's not always the result of being over-torqued by some underpaid gorilla at the dealer, but often that's an issue too.
  10. Jul 23, 2024 at 10:46 AM
    #50
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I believe the plastic expands...I hand-tightened it the last oil change before converting to the aluminum and I had some challenges removing it.
    The aluminum housing on the other hand, came off a lot easier this last oil change.
    Barsoom and Kolohe07[OP] like this.
  11. Jul 23, 2024 at 11:57 AM
    #51
    kahanabob
    Maui
    16 TRD 2WD 4DR
    My issue is am 79 and if there is something i can take apart and it could leak after i put it back together it WILL! LOL
  12. Jul 23, 2024 at 12:20 PM
    #52
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Just leave the cap on - oil changes like sex are supposed to be messy.
    Kolohe07[OP] and kahanabob like this.
  13. Jul 23, 2024 at 12:38 PM
    #53
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    So is this "impact" an impact wrench, impact driver (1/4"), or a drill? The term is sometimes used pretty loosely. And never forget, lefty-loosey/righty-tighty. Unless you're actually using an impact. Then righty-tighty can easily become righty-loosey very quickly..
    Vidman, Barsoom and TacoTime55 like this.
  14. Jul 23, 2024 at 4:56 PM
    #54
    Kolohe07
    Kolohe07 [OP] Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    Its a Ridgid 1/4" impact driver.
    .....and YES it was in the Leftie Loosey mode
    I had to check after reading yer post, LOL
  15. Jul 23, 2024 at 5:15 PM
    #55
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    I do mine every 5k and torque to these specs as well and never had an issue. I do let everything cool off before changing the oil.
  16. Jul 23, 2024 at 8:37 PM
    #56
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    You're supposed to change the oil hot, so that any contaminants are held in suspension. Waiting for everything to cool means the contaminants fall to the bottom of the pan and risk staying inside the engine.
  17. Jul 24, 2024 at 1:23 AM
    #57
    Josephray70
    Joseph
    Grand Rapids, MI
    I don’t change it cold. I wait about twenty minutes after driving home from work. Still plenty hot enough to let everything flow.
  18. Jul 24, 2024 at 6:54 AM
    #58
    Off Topic Guy
    This changes things then. Most people absolutely bewildered are likely assuming your "impact" use was a 3/8 or 1/2" impact wrench with tons of nut busting torque, not a 1/4" driver. Although it'd still be surprising that even a driver wouldn't be able to budge the oil cap loose. Is this on the OEM plastic oil filter canister or an aftermarket aluminum?
    skidooboy likes this.
  19. Jul 24, 2024 at 7:00 AM
    #59
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Yeah, any newer decent impact driver still makes over 100 ft-lb of tq and should have busted it free I'd think.
    Off Topic Guy[QUOTED] likes this.
  20. Jul 24, 2024 at 8:03 AM
    #60
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    We have a winner!
    Not enough torque to snap it loose. You need a decent 3/8" drill type impact to give it the twist speed, shock (hence the name impact) to loosen the stuck drain cap.
    Also guessing you couldnt hold the housing tight enough with the pipe wrench/pliers, causing the tab breaking issue, not the impact itself. Install the housing on the motor, get a GOOD impact driver drill, and it will spin off the drain cap.
    Ski
