Cargo Bed AC Power Outlet - what do you use it for?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MGully, Jul 25, 2016.
  1. Jul 25, 2016 at 6:08 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  2. Jul 25, 2016 at 6:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    I've read here of one using it for a crock pot when on the road a few hours to a campsite. Nice to have your first meal all ready and hot for you after setup.
    BC Hunter likes this.
  3. Jul 25, 2016 at 6:16 PM
    Wichitaf250
    Wichitaf250 Active Member
    For anyone who has something in the 120v range, an easy way too see if your truck will run it is divide watts by volts. So 400 watts at max too 120 volts is 3.3ish amps. Just an easy way too check and see if it will work.
    Peace1 and venkman781 like this.
  4. Jul 25, 2016 at 6:16 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Who really wants to run an inverter when you need to have the truck running ????
    Marbleyard and The hammer like this.
  5. Jul 25, 2016 at 6:49 PM
    Manvan
    Manvan Well-Known Member
    Paul
    2016 SR5 double cab
    Beard trimmer
  6. Jul 25, 2016 at 8:10 PM
    MadisonTaco
    MadisonTaco Well-Known Member
    Madison,WI
    2016 TRD Off-Road DCSB
    Softopper Roof Rack
    PM Sent
    uhplifted[QUOTED] likes this.
  7. Jul 25, 2016 at 8:13 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Do the same when we go to the cabin up north. Keep the crockpot in an old milk crate to keep it from sliding around.
    watersoilair likes this.
  8. Jul 25, 2016 at 8:18 PM
    Kenjiro
    Kenjiro Well-Known Member
    2016 DCSB TRD-OR
    I use it at jobsites without power to charge my 18v batteries
  9. Jul 25, 2016 at 8:35 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Used mine to run my home theater (55" led, dvd player and surround reciever) for 4 days after losing power due to a storm. :thumbsup:
    BSFord, Ch78 and oldschoolczar like this.
  10. Aug 1, 2016 at 4:22 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    No one's hooked up a nice sized tube amp and rocked out on the beach??
    killthehippies likes this.
  11. Aug 1, 2016 at 4:26 PM
    2010gl1800
    2010gl1800 Active Member
    Barry
    Heber AZ
    2016 Tacoma TRD Off Road Access Cab
    Powering my chronograph.
  12. Aug 14, 2016 at 8:11 PM
    tall_paul
    tall_paul Well-Known Member
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    Do many other people use it for a compressor? Debating something like you posted, sig45, or just the standard connect to battery terminal type compressor. Anyone have opinions on what is better?
  13. Aug 14, 2016 at 8:22 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Power went out at work and I used it to run a printer and the router/modem. When I wasn't running the printer I would charge my laptop.
    Used it for tv & internet after a storm also.
  14. Aug 14, 2016 at 8:23 PM
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    would those easily drain your battery with just accessory on? do you gotta run the engine? I assumed this, but surprised to see some of the stuff people use with it so I assume they are running their engines if its for a decent length of time.
  15. Aug 14, 2016 at 8:33 PM
    #35
    harrisonfaulkner
    harrisonfaulkner Well-Known Member
    Harrison
    2016 Tundra 1794 | 1981 Toyota Pickup Rock Crawler
    I use it to blow up my air mattress, which has a built in AC compressor.
    GSDLVR123 likes this.
  16. Aug 15, 2016 at 3:41 AM
    #36
    Sig45
    Mark
    Maine
    From what I've read here - I've not seen a lot that use the outlet. Most seem to connect to the battery. I don't expect to use it a lot as I don't air down/up a lot like some. Mine's for emergency flat repair and since it's stashed in a tote in my bed I figured I'd save the step of popping open the hood and just use the outlet.
    tall_paul[QUOTED] likes this.
  17. Aug 15, 2016 at 5:15 AM
    #37
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    You don't run the engine with the portable power supply. It has 1200 watts and can run a long time on a full charge. Just make sure you charge it at home a day before.
    Hook the 425 power inverter to your battery, run the engine and use an extension cord. Make sure to keep all wires well away from any moving engine components.
    And remember the inverter is only 425 watts so that's my backup. I use the portable 1200 watt power supply. it even has a light and a small air compressor.
    Hope that helps
    Cheers!
  18. Aug 15, 2016 at 5:57 AM
    #38
    TripleEight
    TripleEight Well-Known Member
    2016 Tacoma TRD Off Road DCSB Gray
    I use this one, it fits nicely in the compartment under the rear seat: https://www.amazon.com/Goodyear-i80...=1471265146&sr=8-3&keywords=120v+air+inflator
    IMO it is just more convenient to plug it right into the bed outlet rather than opening the hood and worrying about those clips popping off the battery terminal. It also seems to work much faster than the cheapo 12v compressors I've used in the past.
    tall_paul[QUOTED] and Sig45 like this.
  19. Aug 15, 2016 at 10:03 AM
    #39
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    i hooked up a 60s Sunn Solarus to test a cab i was buying on craigslist.
  20. Aug 15, 2016 at 10:10 AM
    #40
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    The A/C power outlets on that jump starter and inverter are also only 400 Watts.... What am I missing here?
