Cargo Bed Lights
Discussion in '3rd Gen. Tacomas (2016+)' started by LiveFast, Mar 18, 2019.
  1. Mar 18, 2019 at 4:37 PM
    LiveFast
    LiveFast [OP] Well-Known Member
    TRD Off-Road
    One of the two OEM LED lights in my cargo bed went out. If I purchase a new set, are they plug and play as far as replacement goes? Or will I need to rewire the new cables?
  2. Mar 18, 2019 at 6:20 PM
    Boghog1
    Boghog1 Jack of all trades, master of none.
    Southern, NH
    2019 AC V6 4x4 SR
  3. Mar 18, 2019 at 6:29 PM
    LiveFast
    TRD Off-Road
  4. Mar 18, 2019 at 6:33 PM
    Boghog1
    Southern, NH
    2019 AC V6 4x4 SR
  5. Mar 18, 2019 at 11:53 PM
    mrkabc
    mrkabc Well-Known Member
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto 2 strokes & XB LED Fog Lights, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO stuff, PRO grille. Where's the mall?
    If you are replacing the "OEM" ones they are plug and play. Two screws to loosen, follow the wiring harness to the plug that will be zip tied to the frame somewhere. Unplug and remove the wires from the plastic plug carrier using a thin screwdriver. At that point you can pull the wiring harness out through the hole in the bedside.
