Cargo divider questions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aww1970, Oct 28, 2008.
  1. Oct 28, 2008 at 8:48 PM
    aww1970
    aww1970 [OP] Well-Known Member
    2009 Tacoma TRD Long Box
    Who has a cargo divider? Does it run in the factory bed rails?
    I am considering one of these to keep my cooler, pack, etc. from bouncing around on hunting trips. I like to keep gear secure in the back but still accessable. Looking for a review.
    As well is it the same part # for the std. bed as compared th the short bed?
    Thanks.
  2. Oct 28, 2008 at 9:04 PM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It should be the same part number for both the long and short bed. I have a feeling that the OEM cargo divider fits in the rack, but I don't know.
  3. Oct 28, 2008 at 9:14 PM
    Mz_TazComa
    Mz_TazComa Well-Known Member
    Long Island, NY
    '16 D-Cab TRD Sport LB
    Yes it does fit in the factory bed rails. I have a long bed and it fits perfectly.
    I recently installed an Access LE cover (which sits behind the factory bed rails). So I had to cut about an inch off each end of the cargo divider.
    Here are some pics after the cover installation:
  4. Oct 28, 2008 at 9:43 PM
    aww1970
    Will it slide past the wheel wells?
  5. Oct 29, 2008 at 6:50 AM
    Mz_TazComa
    Long Island, NY
    Yes, it slides pasted the wheel wells both before and after installing the cover. I cut an inch off each end so that it still sits in the middle of the truck.
  6. Sep 10, 2009 at 12:33 PM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Long since dead thread but I wanted to say thanks anyway, I am looking at this divider but with my roll up top was concerned the knobs would get in the way (knobs on the divider) but this was a great idea...just turn them upside down...
    Thanks!
  7. Sep 10, 2009 at 12:36 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I have a cheaper version. It's called Loading Zone. It was giving to me as a birthday present from my Girlfriend. It doesn't go into the rails just locks into the sides of the bed. Nothing very special but cheap. It does the trick but I would rather one that goes into the rails. Mine is a pain in the butt to remove and re-install.
  8. Sep 10, 2009 at 12:37 PM
    testedone
    Rick
    U.S.A.
    I am now searching for the posters (pictures above) thread if he has one on cutting the rails, looks like he had to cut them to make it work...
  9. Sep 10, 2009 at 12:44 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I've got the exact same setup as MZ_TazComa (same Tonneau, same orientation with the bed divider, etc).
    I really like the whole setup. I keep the divider slid all the way to the tailgate so there is about 1.5ft to 2ft of space. I can put stuff back there without having it slide all over the bed. I keep a few bungees strapped to the divider so I can bungee things to it if need be.
    It easily slides up and down the rails, easily fits under the Access LE (there is another version of the Access tonneau that sits lower, dont think it will fit under that one), and is even easy to take out and put in (once you get the hang of it).
    For biking, I have to bike mounts on my front rail, the forks of the bikes mount on these. I keep the divider up in front of the bed when I have bikes in the bed, and I secure the spare tires between the divider and the very front of the bed by pushing the divider all the way forward, then tightening down the knobs.
    Anyways, works great for me. I worked it into the deal when I purchased my truck.
  10. Sep 10, 2009 at 12:53 PM
    testedone
    Rick
    U.S.A.
    My cover is by Truxedo and it mounts on the outside of the rails (built in rails) so I am rethinking the factory divider because I won't be able to slide it around as cargo needs dictate. my cover actually has brackets that use the Toyota bed rails as anchor points
  11. Mar 10, 2010 at 2:49 PM
    RustyTaco
    RustyTaco Ex-wife says "Put a bag over my head, I'm a 10".
    Florida and Mid-West
    2010 PreRunner SR5 2.7 + dog
    Aires stainless nerf bars, iPod interface, bed matt, Access Roll-up tonneau, WeatherTech window deflectors, cargo divider. Jack Russell
    Re-Re-Resurecting this thread.
    What brand of cargo dividers have you purchased and from where?
    About the "another version of the Access tonneau that sits lower, dont think it will fit under that one" note. I just ordered an Access Roll-up from Luke at Truck Alterations. Is that the "another version"? Or will all/some cargo divders fit under the tonneau?
    thanks in advance
  12. Mar 10, 2010 at 2:56 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    The Access Rollup will be fine with the OE cargo divider, it is the same profile as the one pictured a few posts above. The Lorado, Vanish and Tonnosport are the ones that it won't work with.
  13. Mar 11, 2010 at 8:39 AM
    Mz_TazComa
    Long Island, NY
    Sorry to took so long to reply :D but here is a pic from cutting the divider... (and again...those aren't my hands =) )
