Cargo light, Siri and Text Message questions????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rob4092xx, Apr 25, 2017.
  1. Apr 25, 2017 at 7:21 PM
    rob4092xx
    rob4092xx [OP] Well-Known Member
    Phoenix, AZ
    I have three issues on my new 2017 Tacoma Limited I cannot seem to resolve or find answers to. I did several searches and read about them but still have the following. Can some of you experts help me out?
    1. I cannot figure out how to receive text messages on my Navigation Screen. According to what I have read, this should be possible???
    2. I read if I hold down the "End phone conversation" button on my steering wheel, I should be able to communicate with Siri. Is this accurate?
    3. I have a cargo bed light switch. I'd like the light to come on when I open any of the doors. I have the switch on "ON" but the light never turns on. In fact, I have never been able to get the light to turn on regardless of the switch position. Am I missing something?
    Thanks for helping a newbie! There is so much to learn abouut these trucks!
  2. Apr 25, 2017 at 7:27 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    1 only when stationary
    2 yes
    3 sounds like a problem, take it to dealer unless you want to check fuse/bulb/connections
    FirstTacoma!! likes this.
  3. Apr 25, 2017 at 7:44 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    1. The Truck will read out the texts when driving. You can't read them as it is distracting.
    2. Hold the Start conversation button. The upper button for about 3 seconds then you can ask Siri a question. Your iPhone must be connected by bluetooth for this to work.
    3. Check your fuse or take back to dealer under warranty. It should come on when the door opens or switched to on.
  4. Apr 25, 2017 at 7:46 PM
    Herniator
    Edmonton
    Check out the tips and tricks in the sticky section. Lots of good stuff there.
  5. Apr 26, 2017 at 5:22 AM
    rob4092xx
    Phoenix, AZ
    Thanks so much everyone!
  6. Apr 26, 2017 at 5:39 AM
    rob4092xx
    Phoenix, AZ
    I looked in the owner's manual and could not find a list of fuses. Does anyone know what fuse and/or which fuse box the cargo light fuse is in? Thanks!
  7. Apr 26, 2017 at 7:44 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Look below the steering column.
    Find fuse box. It has a white cover with labels on it.
    Should be a fuse for cargo lights. 7.5a IIRC
  8. Apr 26, 2017 at 7:50 AM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Can confirm, this is accurate.
  9. Apr 26, 2017 at 7:56 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Mine did this on the drive home from the dealership. Never again, and I can't for the life of me figure out why!
    swordfish likes this.
  10. Apr 26, 2017 at 8:02 AM
    -JDC-
    -JDC- Well-Known Member
    2017 TRD Off Road
    If you have contact shortcuts programmed on your home screen, then the text voice read function will not work with iPhone. Also make sure you have notifications enabled in your iPhone bluetooth Toyota Tacoma device settings. I believe this is off by default.
  11. Apr 26, 2017 at 8:03 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    I once got it to read a message. No clue what I did or didn't do differently. Usually it just tells me that I got a message... thanks.
  12. Apr 26, 2017 at 12:02 PM
    rob4092xx
    Phoenix, AZ
    Checked the Cargo Light fuse and it is good. Replaced it anyway just to be certain. Any other ideas as to why it is not turning on? Does it need to be night time?
  13. Apr 26, 2017 at 12:37 PM
    Herniator
    Edmonton
    Could also be a faulty switch or the LED lights are toast. Let the Dealer look at it. Maybe you'll get a free wash out of it.
  14. Apr 26, 2017 at 5:28 PM
    Overland_Odyssey
    Overland_Odyssey I talk about 4x4s.
    Rich
    2017 Silver DCSB TRD Off Road
    After about 4 months of trying, I got it to read the texts for about 2 months then it stopped. I've bever been able to get it back. I've given up on it. The contact shortcut comment is not correct. I had shortcuts programmed in when it was working and removing them didn't help.
