Cargo Tie-down Assembly D-ring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, Jan 25, 2018.
  1. Jan 25, 2018 at 3:27 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    gunny1005 likes this.
  2. Jan 25, 2018 at 3:28 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Well...how much were they??
  3. Jan 25, 2018 at 3:31 PM
    NMTrailRider
    New Mexico
    VirusCage[QUOTED] likes this.
  4. Jan 25, 2018 at 4:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Dodge sprinter D rings are even beefier and cheaper 5 bucks a piece. Thats what i have on my middle and front bed bolts.
    That stated those would be nice in a spot where there isnt already a proper holding bolt.
  5. Jan 25, 2018 at 4:39 PM
    NMTrailRider
    New Mexico
    Yep I saw the Dodge rings in another thread. I didn't want to tie into the bed bolts. It opens up potential for corrosion/rust (that's simply my opinion, don't care to argue here).
    The weak link in installing somewhere other than the bed bolts will most certainly be the composite material itself.
    In that regard, I liked the OEM option better, as it comes with a sizable backing plate (with welded nut) and is engineered to maintain full rotation. The backing plate on the OEM rings will be plenty for whatever I need to tie down.
