Carlink ASCL6 help needed
Discussion in 'Toyota Trucks & SUVs' started by knight3136, Mar 4, 2024.
  1. Mar 4, 2024 at 6:04 PM
    knight3136
    knight3136 [OP] New Member
    I have a 2020 Rav4 XLE Premim. I was able to connect the start-x to carlink when I got the unit about 16 months ago. But I had a dead battery and the pairing between carlink and start-x starter was lost. I'm able to start the vehicle using the key fob, but nothing happens with the app. I already reset the start-x , disconnected the 8 pin connector from carlink module, uninstalled the app from the cell , and removed and added the vehicle over again in the app. But all I get is a flashing red light in the carlink module. Has anyone else experience this and how were you able to fix it ? I tried contacting the manufacturer and all they tell me is that the device is defective. I asked them how can their module break by removing power. It should be able to pair up again once you go through the pairing process.
  2. Jan 4, 2025 at 8:09 AM
    mrkvrb
    mrkvrb New Member
    i had the same dead battery issue. your cl6 gps unit is junk now. i had to buy a new one
