Carpet headliner
Discussion in 'Tonneau Covers, Caps and Shells' started by PHILLIE PHANATIC, Jan 23, 2019.
  1. Jan 23, 2019 at 4:02 PM
    PHILLIE PHANATIC
    PHILLIE PHANATIC [OP] Active Member
    Bob
    2015 Barcelona Red Double Cab SR5
    Does anyone know if the caps that are carpet lined, is that actual carpet or a sprayed on product from the factory? I purchased a used Leer midrise that is just painted white fiberglass, but I really like the lined caps and was wondering if it's something that could be done aftermarket?
  2. Jan 23, 2019 at 4:20 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    It’s actually carpet
    I personally didn’t want carpet but do plan on painting or bed liner the inside a dark grey or black
    Might try a local dealer to see if they could order it for you but other than that I’d guess it’s not a pre cut piece. But rather a roll that’s adhesive in place and trimmed around the windows and folded over the lip
  3. Jan 23, 2019 at 4:25 PM
    PHILLIE PHANATIC
    Bob
    Sounds like a hard job, I thought about using colored bed liner, won't be much smoother that the painted fiberglass though.
  4. Jan 23, 2019 at 4:41 PM
    PHILLIE PHANATIC
    Bob
    How about Plastic Dip, think that would work ?
  5. Jan 23, 2019 at 5:34 PM
    baldbeardedtaco
    FL
    I don’t care about trying to smooth it out, it’s already a rough texture. That was kinda the point of the bed liner. I wouldn’t use plasti dip but I have never used it either
    The tech at the dealer told me about grizzly grip and that’s what he’d personally use but after reading on their site it’s mainly used for under carriage etc with a rubber/flexibility. I don’t think that’s absolutely necessary for my needs so I’ll just grab whatever bed liner
  6. Jan 23, 2019 at 11:05 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    The carpet on caps is basically like trunk liner carpet or subwoofer box carpet. It's cheap to purchase by the yard and very easy to install using spray adhesive.
