Carpet Removal... Ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SnowroxKT, Jul 20, 2014.
  1. Jul 20, 2014 at 5:06 PM
    SnowroxKT
    SnowroxKT [OP] Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Alright so I just got back online and got me a Tacoma! The carpet is pretty much shot and does not fit like it ought to... Thinking someone replaced it with the wrong carpet kit. Not to mention carpet is blue and truck interior is tan... Weird.
    So, I am thinking of ripping all the carpet out and getting some kind of bed liner sprayed/rolled or paint. Anyone ever done this before? I realize it will be noisier without the insulation on the back of the carpet. I also realize I drive a truck. :cool:
  2. Jul 20, 2014 at 5:13 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    There are aftermarket carpet sets available, but if you want to go the bed liner route, I would suggest rhino liner because it is a little bit rubbery compared to LineEx, Rustoleum etc. that dry very hard. I would think a little softer surface would be better inside the truck, incase you drop something etc.
  3. Jul 20, 2014 at 5:53 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Yeah, I think the more rubbery one would be the best for this application, it would even dull some of the sounds coming from underneath.
    Would running just sheet metal be bad? I think it would increase rate of rust...
  4. Jul 21, 2014 at 11:56 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Well, cleaned her up tonight and she is sitting carpet free. Took pics just no time to upload at the moment. Time for bed. :)
  5. Jul 23, 2014 at 6:31 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    If the truck is a daily driver I would seriously advise against ripping the carpet out and not replacing it. A buddy did this and sprayed in a bed liner in his Ram and hated life afterward. It was loud even on smooth roads and got hot inside pretty quickly. I'm willing to bet it would have been pretty cold during the winter months as well.
    He drove the truck for a couple of weeks before scraping all the bed liner off to put down Dynomat, padding and new carpet.
    At some point in the future I'm going to follow his lead as my trucks carpet has seen better days.
  6. Jul 23, 2014 at 6:35 AM
    Madjik_Man
    Colorado Front Range
    Dynomat won't do much on the floor pan. Dynomat (and the likes) are meant to make flimsy panels stiffer to cut down on the resonance.
    The floor pan is already a very sturdy and stiff piece of metal (for obvious reasons). If you want to cut down on noise and heat from the floor pan then you need to use Mass Loaded Vinyl.
    Unless you're a finely tuned audiophile going for the ultimate sound in your truck, Dynomat on the floor pan is pretty much a large waste of money.
  7. Jul 23, 2014 at 7:54 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Thanks for the advice guys, I really do appreciate it... That being said.
    It really isn't THAT noisy. I am sure I will lose some insulation value, but I will gain ease of cleaning after wheeling/camping/roadtripping. And up here in the winters carpet pretty much never dries out, so this outta help. If I hate it I can always through a carpet kit over the bed liner.
  8. Jul 23, 2014 at 8:07 AM
    areghas
    areghas Active Member
    Cannon AFB
    6in ProComp lift, 33" tires.
    I did this to my tacoma about 5 years ago. It's a bit loud, but I've never regretted it. It's easy to clean with no carpet and just a bed liner. Typically, I take the seats out and just hose out the inside, it dries in an hour or so, or if need be, I'll dry it with some rags. I also took out all the rubber plugs to facilitate easier draining. I don't mind the noise. I can post pics of the interior if you would like.
  9. Jul 23, 2014 at 8:14 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Yeah I would love to see it if you don't mind throwing up a couple pics. Do you drive without the plugs in? I would imagine that is where most of your noise is coming from... I want me drain holes plugged, but removable. Not sure if that is possible and if it isn't then I will just bed line them in place.
  10. Aug 9, 2014 at 12:56 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Got a pic? I would like to see this.
  11. Aug 9, 2014 at 1:13 PM
    tagaman670
    tagaman670 Hafa Adai!
    joey
    Saipan, CNMI
    White "BAJA" DCSB
    performance shift knob +5hp decal Tint Rockford Fosgate 6x9's JL Audio 8" Sub RockFord Fosgate POWER 550x amp
    Why not just get a HD vinyl flooring . Like my baja truck and the rest of the bajas they don't have carpet but like a vinyl type flooring. Check camelback toyota and see if the have any plus it should be pre-cut to fit directly into the truck
  12. Aug 14, 2014 at 1:00 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I don't seem to be finding any, got a link?
