Carrier Bearing… Alternatives and Solutions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 2, 2016.
  1. Mar 11, 2016 at 7:03 AM
    #61
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
  2. Mar 11, 2016 at 7:56 AM
    #62
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    AWESOME!!! see i knew a proper CB would fix alot of issues.
    My only concern is that it looks like the bearing itself is not sealed. how does the bearing keep dirt out?
  3. Mar 11, 2016 at 9:13 AM
    #63
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Looks like your driveshaft may either be A. Out of balance, or B. Have bad angles. You may want to figure out which it is first before you do anything to it, because not even a new carrier bearing will help and will actually be ruined quickly if you have either one of those wrong.
    It looks decent at best. Do you have take off shudder? You may want to consider doing the mod regardless as a prevantative maintenance item.
    You know, that's a great question. The bearing itself I believe is a high quality race bearing that they use for those applications, so it is sealed similar to the style wheel bearings are, but as far as shielding and the rest goes I am not sure. I am not even sure if you could build a makeshift greaseable nipple for it either. Do you have any ideas?
    JustinL[QUOTED] likes this.
  4. Mar 11, 2016 at 9:43 AM
    #64
    nd4spdbh
    SoCal
    well i just see in the pictures of the bearing by itself exposed grease. I couldnt make out any seals like you would see on a sealed bearing. Let me email inland driveline supply. Ill report back what they say.
    Crom likes this.
  5. Mar 11, 2016 at 9:45 AM
    #65
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's not a bad idea. I'll see if I could call them and ask them as well. Remember, this CB is for a ranger, but it fits ours due to ours having the same ID specs as their driveshaft.
  6. Mar 11, 2016 at 9:51 AM
    #66
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    That was from about 2 years ago. pulled off the cb and replaced it and the ujoint, no vibrations since! though like i said, my current cb is getting pretty sloppy, but that's after 2 years of hard use, and i still can't feel any vibes. will probably upgrade to the one you have when the time comes
  7. Mar 11, 2016 at 9:52 AM
    #67
    nd4spdbh
    SoCal
  8. Mar 11, 2016 at 9:55 AM
    #68
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's only one shield though. I see what you are saying though. We would need two of them to better seal up the CB wouldn't we? That also would have had to go on before they reassembled everything yeah?
  9. Mar 11, 2016 at 9:57 AM
    #69
    nd4spdbh
    SoCal
    yes, they go on before. I have seen some driveshafts that have them built in on the non yoke side so only one would need to be put on.
  10. Mar 11, 2016 at 9:59 AM
    #70
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hmm I see what you are saying… I should call up Inland and see what they think about all this. I have this all together now so pulling it apart would suck just for a shield you know?
  11. Mar 11, 2016 at 10:01 AM
    #71
    nd4spdbh
    SoCal
    Big time. I emailed them to see if the bearing itself inside the part number you used is a sealed unit, if it is.... no worries run it!
  12. Mar 11, 2016 at 10:05 AM
    #72
    Iamraiderpower
    Iamraiderpower Well-Known Member
    of course its somewhere in this thread I am sure, but has anyone upgraded to a 1 piece DS? I know I have seen some posts floating around but cant seem to locate them
  13. Mar 11, 2016 at 10:06 AM
    #73
    nd4spdbh
    SoCal
    see below
    All is good in the world.
    12TRDTacoma[QUOTED][OP] and Crom like this.
  14. Mar 11, 2016 at 11:31 AM
    #74
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Told ya. ;)
    Haha.
    As the world continues to turn..
  15. Mar 11, 2016 at 11:34 AM
    #75
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There are mixed reviews about it. Some people complain about them vibrating, some don't. I'd rather just modify factory to make it a better unit. That way I know there will be no potential issues.
  16. Mar 11, 2016 at 11:36 AM
    #76
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    OP, so how long have you had it installed?
    Looks like a great alternative and they are local. :thumbsup:
  17. Mar 11, 2016 at 12:14 PM
    #77
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have had it installed for about 3 days now. It has been an absolute godsend in terms of NVH. I don't feel a thing from it and it keeps the driveshaft nice and straight during take offs and acceleration as it should. I have driven it both highway and city and in both situations it has performed outstanding!
  18. Mar 11, 2016 at 2:04 PM
    #78
    nd4spdbh
    SoCal
    ugh.... i did not need to spend another 120+mounting fees on the truck... but the lil vibes annoy the hell outta me!
    12TRDTacoma[OP] likes this.
  19. Mar 11, 2016 at 2:35 PM
    #79
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    :popcorn:
  20. Mar 11, 2016 at 3:11 PM
    #80
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Nice work! I can see this becoming a big thread.
