Carrier Bearing… Alternatives and Solutions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 2, 2016.
  1. Oct 12, 2018 at 11:01 AM
    #161
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    HEll yeah, im tired of these slop in the CB replacements.
  2. Oct 12, 2018 at 11:08 AM
    #162
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    I went single piece tom woods driveshaft about a year ago and have had no issues with it. As far as cost, my oem shaft sold the first day I listed it at $200, so it kinda offset the cost.
    MTopp and TireFire like this.
  3. Oct 12, 2018 at 3:14 PM
    #163
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    It will physically fit a Prerunner and can be installed. I'm running it on my Prerunner. See post 88 & 89 of my build thread (https://www.tacomaworld.com/threads/buyobuyos-build-thread.511891/page-5#post-17515509). It is not a straight bolt on part, and it will require making a bracket to support the bearing and spacers to put it at the correct height.
    With that being said, you may run into issues because it is a lot stiffer than the factory carrier bearing and may not let the driveshaft move like it should. I discovered that my rear diff was leaking at the pinion oil seal after running it for 4 months. However, the leak could have also been caused by running around for 4 months before installing it with the u-joint at the pinion totally screwed, and it just took a while to show up because there was about 1-2 month during that 4 months after install when I basically didn't drive my truck. I just got my truck back from having the rear LT suspension installed and have a new driveshaft with a slipjoint after the carrier bearing, so it shouldn't be an issue for me anymore.
    ChadsPride[QUOTED] likes this.
  4. Oct 12, 2018 at 3:20 PM
    #164
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Sounds 100% more likely the leak developed due to the defective u-joint.
  5. Oct 12, 2018 at 3:20 PM
    #165
    ChadsPride
    Sponsored by TacomaWorld.com
    Dang, that looks pretty nice.
    buyobuyo[QUOTED] likes this.
  6. Oct 13, 2018 at 5:35 AM
    #166
    badger
    badger Well-Known Member
    07 SR5
    No, it is rubber, but a totally different design from stock. It is not sloppy at all. If you want it, PM me.
  7. Oct 13, 2018 at 5:43 AM
    #167
    badger
    07 SR5
    These aftermarket center bearings are definitely not designed for a shaft without a slip joint. There are two problems. The rubber is not meant to move axially, and the metal cage is not strong enough. It will fatigue and fail. Even with a slip joint, I welded reinforcements into my cage. A driveline without a slip joint is bullshit. Apparently, Toyota chose to let the sloppy factory carrier take up the movement. The best course is to do what buyobuyo did and replace the shaft with one with a slip joint, and then use one of these carrier options.
    MTopp and ChadsPride like this.
  8. Oct 13, 2018 at 5:53 AM
    #168
    ChadsPride
    Yikes, that sounds pretty involved (and expensive)
  9. Oct 13, 2018 at 7:05 AM
    #169
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    My new driveshaft was $450. Also, it can be hard to find a shop that will do a custom 2-piece driveshaft. Tom Woods who everyone goes to for 1-piece driveshafts for our trucks won't even consider doing a 2-piece driveshaft.
    MTopp, lynyrd3 and ChadsPride[QUOTED] like this.
  10. Oct 13, 2018 at 7:25 AM
    #170
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    Has anyone cut one of the stock bearings open to see how the bearing is assembled/supported?
    My '99 has this issue and I've been debating getting a cheap rubber one and filling it with silicone to stiffen it up.
    Marc70 and ChadsPride like this.
  11. Oct 13, 2018 at 8:25 AM
    #171
    ChadsPride
    Would I be able to get away with 1p on my truck?
  12. Oct 13, 2018 at 9:10 AM
    #172
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Maybe, but I don't know for sure.
  13. Apr 30, 2019 at 1:12 PM
    #173
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    @12TRDTacoma I have a DCLB too, is the 1/8th inch plate necessary? Thanks
  14. Apr 30, 2019 at 1:16 PM
    #174
    TireFire
    Olympic Peninsula
    Question is, why do you want that?
  15. Apr 30, 2019 at 3:03 PM
    #175
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes it is. As it will close the bearing bushing on the open end. Otherwise it would be flopping around on nothing.
  16. Apr 30, 2019 at 3:04 PM
    #176
    GT7
    Grant
    Phoenix
    2013 DCLB
    10-4 ill make one then
  17. Jun 4, 2019 at 6:32 PM
    #177
    GT7
    Grant
    Phoenix
    2013 DCLB
    Welp been getting serious vibes lately and sure enough my carrier bearing is toast
    lynyrd3 likes this.
  18. Sep 28, 2019 at 6:53 AM
    #178
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    So with this installed it looks like the whole shaft will be dropped a little bit. I just got the CB off another member and wanna install it. Just wanna make sure the drop wont cause issues. I only have a 1” lift in the rear.
  19. Sep 28, 2019 at 7:36 AM
    #179
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The large drop will cause you issues unless you flip it around like others have and then use some some sort of stack to space the carrier bearing back down some. You will have to play with the angles, but ideally you want the DS straight all the way through. You can see it visually when you are doing it. I run a 2.25" thick leafpack and I ran mine the opposite way of how most run theirs. I haven't had any problems whatsoever, but my lift is also substantial.
  20. Sep 28, 2019 at 7:49 AM
    #180
    hyper15125
    NJ (609)
    I was thinking of running it upside down with a thick piece of metal to reinforce it at the bottom where the opening would be and some sort or spacer like below to get the correct angle for the shaft. 723E9B95-029A-43C9-B6CE-AEFCC26E1928.jpg
