carrier bearing. 2 WD.
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, May 15, 2014.
  1. May 15, 2014 at 5:37 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Greased my u joints. Pushed up on the driveshaft at the carrier bearing. Shaft moves about 3/4" up and down and back and forth. Not normal am I correct? 359000 miles.
  2. May 15, 2014 at 10:41 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Id it making sounds or vibrations?
  3. May 16, 2014 at 12:07 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Not making noise but there is a vibration present between 60 and 70 mph. I rotasted the tires and the vibrations are still there.
  4. May 16, 2014 at 12:13 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I think any truck with that many miles is going to see a great deal of driveline wear and the bearing is probably pretty shot. as far as the play goes, I think the carrier bearing has play to begin with. I have a little play in mine and always have.
    although I have a vibe around the same speed so maybe I'm in the same boat
  5. May 16, 2014 at 3:43 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    That was a symptom of mine when it went bad, vibration at 65-75 mph. Also had some strange vibration when depressing the clutch because of the change in torque. My advice is if the funds allow it, buy a cheap one ($25-30) to see if that's your problem.
