Carrier bearing 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Starlaketacoma, Jul 22, 2023.
  1. Jul 22, 2023 at 11:35 AM
    Starlaketacoma
    Starlaketacoma [OP] Active Member
    2010 tacoma dblcb v6 4x4
    4 inch front spacer, 4 inch rear block, off-road tires
    Hey all, so I have a drop bracket lift and a csb drop kit and never had any problems before but with the new carrier bearing I put in the drivetrain is rubbing on the lower section of the rubber housing on the new carrier bearing. It wasn't doing this with the other csb. It looks like it needs to be dropped another 1/8th-1/4 inch to be centered in the csb so it doesn't rub. Replaced all u joints as well.
    Thoughts? Was thinking of just putting another one or two washers in there to get it centered but it's hard to find those washers. Was also thinking that it's this csb that's just not made to spec so it's causing the drivetrain to sit lower in the csb than it should.
    It's a precision CSB.
  2. Jul 22, 2023 at 4:58 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Carrier bearing drop kit
    15 mins in your driveway
  3. Jul 22, 2023 at 5:15 PM
    Starlaketacoma
    Yea I think I'm just gonna throw another 1/4 to 1/2 plate in there to drop it down a little more. Already have 4 washers and a spacer but might only need another 1/4 inch to make it work. Just weird that this csb is causing the issue when the other one wasn't. I'll stay away from precision csb's in the future and get dorman or something better.
  4. Jul 22, 2023 at 5:53 PM
    TacoTuesday1
    SD CA
    used to run stock bearing with OME drop spacer kit.
    then switched to IEDLS poly, flipped it I believe, and put some sleeves as spacers to mimic where the previous setup was. Using stock metal tubes for welding (DOM) I got from a good hardware store that just so happened to hold it at the same length. Used a tape measure.
    not sure what precision CSB is.
    I believe there’s charts for angles. And people use an app on their phone to determine the angles of each shaft and adjust as needed. But I didn’t bother with that.
  5. Jul 22, 2023 at 10:32 PM
    Starlaketacoma
    That sounds sick. Definitely gonna look into doing that instead cause just adding more spacers and washers to the drop im sure is creating less integrity in the securing bracket.
    Precision is the brand of the CSB (center support bearing)
