Carrier bearing alignment question
Discussion in 'Suspension' started by Beast Mode, Oct 15, 2012.
  1. Oct 15, 2012 at 8:35 PM
    Beast Mode
    Beast Mode [OP] Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    background: 2012 DC 4x4 with OME lift. I've had vibes since day one and have slowly been adding washers to the CB. I've been able to get the takeoff shudder just about completely resolved, but cannot get rid of the 60mph + vibe taken care of. The question I have is regarding the alignment of the CB with the bolts before tightening. Kind of confusing to describe, but on each side of the CB where the bolt goes thru there's not really a "hole", but rather a slide where you can manipulate the CB before tightening. The question finally is "what placement have you guys gone with that provided the best results"? My instinct is telling me in the middle. Currently I'm on the end. Does it make a difference?
    Here's a pic of the bolt slip I'm referring to on the CB.
  2. Oct 15, 2012 at 8:36 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Ive been wondering the same, mines almost straight no vibes tho:eek:
  3. Oct 15, 2012 at 9:01 PM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Matt, how are you bolted up? front, middle, back?
  4. Oct 15, 2012 at 10:51 PM
    Blacktacoma23
    2011 Mall Crawler
    Pretty sure the middle, just a CB drop with my lift kit actually cured the vibes
    ill check tomorrow
